Old 31st May 2011, 08:03 PM
Curtis's Avatar
Curtis Curtis is offline
Default auto windows
are PF d2 A8's suppose to have auto up and down on all 4 windows? currently only the drivers side goes down on auto and the others have to have the switch held till closed or open.they are also very slow.
Old 31st May 2011, 09:46 PM
they need to be wound all the way down and up once to calibrate before they will auto up/down. If you've had the battery off or its been flat at all then they reset and need a quick wind down/up to cure.
The drivers one works as you've likely had that down and up as a matter of course..
Old 1st June 2011, 07:49 AM
Curtis's Avatar
i have done that for all four windows and still nothing.i did notice there is a diagram on the passenger footwell under the carpets saying there is a relays for auto up windows but i cannot find them
Old 26th June 2011, 09:50 AM
Curtis's Avatar
any way to fix slow windows?
Old 26th June 2011, 10:18 AM
The motor could be tired but try lubricating the guides.
Old 21st July 2011, 10:00 AM
Curtis's Avatar
my luck its the motor. it has its moments when its quick and when its slow could be jamming on the guides. can i use normal oil or silicone spray to lubricate the guides?
Old 21st July 2011, 12:34 PM
The rear windows on a D2 should auto down after a brief tap on the switch, but they don't auto up at the back for 'safety reasons' despite them having anti-trap. Think that's the same from the front or rear switches - certainly is from the drivers panel anyway.
Old 22nd July 2011, 06:17 AM
Curtis's Avatar
mine only have auto down on drivers window.the battery was disconnected for while and when i bought the car i had to replace the battery.would it not have to be sorted out on a vag machine?
i did notice on the sticker for the fuses and relays in the passenger footwell that there should be a relay or fuse for the window control but i cannot find it
Old 22nd July 2011, 10:06 AM
You just need to work the windows all the way up and down to reset the auto-up/down function.
Old 22nd July 2011, 11:05 AM
Curtis's Avatar
doesnt work.did every model have auto windows? its my luck to be the one without auto windows.
