Old 21st June 2011, 01:27 AM
jayzee jayzee is offline
Default Interesting...
http://forums.audiworld.com/showthread.php?t=2801728
Yeah baby!!
Old 21st June 2011, 06:46 AM
Good find. Added to sticky. Thanks.
Old 21st June 2011, 10:57 AM
holy crap !! i have just payed A8 parts £80+postage for 2 new valves and when i changed them and started it up nothing happened like that they stayed the same even when the engine was started ??? what the hell ...... do i have a sized intake flap maybe ?
Old 21st June 2011, 11:34 AM
will this fault throw any engine management codes over time, or just feel like the engine's a bit short of torque?
Old 21st June 2011, 12:30 PM
No engine management light, easiest way is to take off the main front engine cover and check.
Guy (I got your PM btw will reply later) all you need to buy is the metal replacement connecting rod that breaks usually. Its easy to fit, saying that it took me an hour and I still couldn't get it on. Ben put it on in under a minute for me
Old 21st June 2011, 12:44 PM
well thats that now bloody thing i feel deflated and fed up now just stripped it all down to follow the guide that was on the link and now i need a new inlet manifold yes car feels low on power not a great deal but in the high revs it lacks that extra pull that it once had, oh and amar by the way i replaced the links you were on about quite some time ago and i did not think they were working properly then..... they were solid to get out i managed to get the insert out with the o ring on no problem but the plastic bit that fits inside that and rotates just fell to bits
going to fit the new breaks now instead il have to scout ebay for a new manifold gutted
Old 21st June 2011, 12:58 PM
Ah ok, you probably did need the new ones then. Sometimes they need replacement in full.
Old 21st June 2011, 01:23 PM
Oh dear, what have I started!
Mkoneman found these a while back http://forum.a8parts.co.uk/showthread.php?t=2582
Yeah baby!!
is there a link anywhere to changing the front discs as im doing it now and there is no guide on taking the caliper of ti get the disc off only a guide on how to change pads witch dose not require taking the caliper off ???
Old 21st June 2011, 03:14 PM
Caliper needs the torx style bolts removed IIRC and could need a seriously big breaker bar
