Old 24th June 2011, 07:46 PM
Default Fingers Too Fat
Anybody got any tips on how to remove the bulbs in the lights in the bottom of the rear view mirror, fingers are too fat to fit through the hole to get a grip of them
thanks
Old 24th June 2011, 08:06 PM
Brian, I don't know how bulb looks like, but try to take a piece of rubber hose and put the end of hose on the lamp. Then grab hose from both sides.
Also, try to take vinyl electrical tape and try if you can wrap the lamp with that tape so the lamp becomes "longer" with tape on it, so it'll be easier to grab.
Try to find pincette / tweezers and wrap it with electrical vinyl tape, so it can actually grab glass object.
Old 24th June 2011, 08:07 PM
What's Connor doing? Set him to work!
Old 24th June 2011, 08:24 PM
tried that one even his fingers are too big
Old 24th June 2011, 08:27 PM
like the sound of those Sergey, its a normal push/turn type of bulb with pins, much like a household one, think you have to push it in and turn, the rubber hose/tape option sounds good will give it a try
thanks
Old 24th June 2011, 08:30 PM
darrenjoe90's Avatar
i cant remember how i did it but i will have a look in the morning for you
Audi S8 Phantom Black
Old 26th June 2011, 11:05 AM
Oli18's Avatar
Oli18 Oli18 is offline
A thin set of pliers covered in tape for protection works a treat!
Audi A8/S8 D2 Flickr Group
