Old 22nd February 2009, 05:45 PM
GregLo
Guest
Posts: n/a
Default steering issue
previously my power steering had been becoming increasingly tight on right turns only, at first it was only happening from time to time now its constant' this is a US model . I had a local alignment shop check the entire front end, they found nothing . Other than the fact they said I needed a new rack. My question is could this be just a clogged valve in the rack , simply because turning left isn't a problem ., during my inspection of the fluid I noticed it was darker then it should be If I do flush it is there any thing I could use or should i just use the normal pentosin to flush and fill
Greg
