i had my front bumper replaced on my d2, but the sensors do not work. i was wondering if there is any way i could make the one except for the front ones work...the car just makes a high pitched beep which i switch off by pressing the sensor button, because its so annoying
Hey up!
May be able to code out - I have your old sensors still chapo bu they are all severely broken! SHould be able to code the ECU to rear sensors only - I'll check ELSA coding and send you if there's someone down there who can code for you.... ![]() |
Hey Ben,
I have the opposite problem...one of my rear sensors have gone. I do have a new replacement but not gotten round to painting it green yet! Curious as to whether I could code out the rears allowing only the fronts to work and get rid of that annoying beep? -=Glyn=- |
![]() Quote:
plus, i had them check the steering wheel leek, and they didnīt say anything about the part that needs changing. do you remember the name of the part? regards |
