Old 20th September 2011, 12:44 PM
Stuarta Stuarta is offline
Default removing ancient protective trim
Hi all,
I was quite pleased when I bought my A8 to find the original factory protective film (blue stuff) on the metal trim parts of the sill kick plates - hence, no scratches. Now, though, I've tried removing it but it's damn near impossible to do without just pulling off tiny pieces at a time. Any suggestions?
Old 20th September 2011, 12:48 PM
try heating it gently with a hairdryer then pulling it off slowly as it cools
Old 20th September 2011, 02:20 PM
Iyole Iyole is offline
If the SO's Hair Dryer doesn't work you can use " Label-Off "
I use it for removing decals/badges etc etc.... works like a charm....
http://www.homecrafts.co.uk/products...pray_LO200.htm
2002 S8 D2 F/L
Old 20th September 2011, 03:11 PM
thanks, will have a go.
Old 21st September 2011, 08:07 AM
Ha, ha you said pulling it off slowly
Old 21st September 2011, 12:33 PM
Did the first one today with a heat gun and scraper - took a few goes to figure out how much heat but worked a charm. Now just need to remove the remaining goo and give it a good clean before re-installing.
Old 21st September 2011, 04:19 PM
Nice one!
Glad you got it sorted
