Old 19th October 2011, 07:16 PM
Default can the head lights be calibrated ?
can my self head lights be calibrated via vag com ? they are a little low and need to come up a little so i can see where i'm going
thanks guy's
Old 19th October 2011, 08:20 PM
I used to move the headlights up and down on my S8 using Vag Com but that was just to check the auto levelling. There must be a way to do it, I'm sure MOT stations can do it.
Old 19th October 2011, 10:00 PM
Mine failed MOT on headlight aim, despite being bi-xenons with auto levelling. There are still manual adjustments on the headlights, even with auto levelling, to set the basic position. The MOT station corrected my driver's side one (too low and toward the left) FOC and it did make a noticeable difference. I assume it didn't quite go back in the same place after removal for the cambelt change.
If you have someone with decent beam setting kit they should be able to do it in a few minutes.
Old 20th October 2011, 09:09 AM
ah thanks guys il give that a go then, there is a reason i cant see where im going may have dropped by its self after the coilovers were put on i had both sensors off when i did the change over
