Old 3rd November 2011, 07:15 PM
Default RNS-E SD cards
I'm not sure if D3 '8s have SD card slots that do or don't recognise SDHC so thought I'd post here, as anyone with an RNS-E or SD adaptor in a D2 will have retro-fitted it in any case!
I've had loads of issues buying SD cards in 4GB capacity off ebay that turn out to be SDHC (they are basically generic SDHC cards with a knock-off SD branding) and therefore don't work in an RNS-E or anything else that isn't post-SDHC introduction.
I ordered 4 from this place a few days ago and they turned up yesterday - I've successfully tested one, having formatted to FAT32 and dumped some MP3s on it - so can confirm they are correct SD cards to the old standard.
http://www.inkubus.co.uk/product.php/5385/0
They are currently out of stock, but will be getting more in and I'll definitely be getting some more. At this price they're considerably cheaper than Amazon etc. Also note that if you do their online checkout and want more than a couple the postage charge rockets to a fiver - if you call and order over the phone they'll amend it to £2.50.
Adrian
Old 3rd November 2011, 07:19 PM
I thought that generally there was a technical limit of 2GB for "proper" SD cards.
There are some 4GB cards on sale, but depending on how "standard" your equipment is they may well not work.
Old 3rd November 2011, 07:53 PM
4GB is the limit that fully meets the standard - there are some 8GB cards which are really 2x4GB cards but they're not common or compatible with most.
My RNS-E doesn't recognise the card size correctly at all, but does recognise all the content. Think when the RNS-E was developed the limit was about 512MB!
Old 3rd November 2011, 07:55 PM
On the D3 you'd have the AMI installed - Use it with the USB interface and you can hook up any amount of USB based storage, SDHC, HDD etc.
The no-sdhc support of the RNS-E is fast becoming an annoying limitation...
Old 3rd November 2011, 08:01 PM
I haven't bothered looking in depth, but gather the later style RNS-E with chrome volume control accepts SDHC as well as having a higher resolution screen. Think it's mainly fitted to A3 derived models in a form that would be relatively straightforward to retrofit to an '8 IF you have a donor faceplate from an older RNS-E to fit as the newer ones are too small.
Cost is pretty prohibitive though......about £800 for the newer unit alone.
Old 3rd November 2011, 08:04 PM
my A7 has a 16 gig and an 8 gig SDHC card in it and seems to play almost any format ive tried so far. . .
Old 3rd November 2011, 08:30 PM
ahh, but bet it wont do 78's (suspect only Jim may understand this one)
Old 3rd November 2011, 08:34 PM
lol
Gimme 45 or 33 anyday - You just cannot beat analogue sound - The science is flawless....
Old 4th November 2011, 12:14 AM
Seventy whats???
Old 4th November 2011, 09:48 AM
lol .. Wee man got a bit of vinyl with his music mag the other week and looked at it like it was something from the ark Reckon he only knows about LPs as he saw ours in the loft a few months ago.
