Old 29th November 2011, 01:00 PM
Default Front D3 Air Suspension Rattle
Hello folks.
I bought a 2006 D3 A8 a month or so ago, and it has a rattle from the front suspension. It is a lightweight continuos rattle over joints in the road, drain covers and cobbles. It doesn't really clunk, it just rattles up to several times a second. I don't really get the problem on the open road or motorway, just around cities. It happens at all damper settings/ride heights.
Are there any common weak spots for this?
On other cars I have had similar rattles from top strut mounts and anti-roll bar links but the latter don't look obviously worn and don't have balljoints anyway.
Thanks for any tips or experience. PS, the mileage is 180,000.
Old 29th November 2011, 02:47 PM
A8 Doc A8 Doc is offline
Wow some mileage!!
Probably the upper suspension arms. They are well known for cracking, not completely but small cracks and obviously arn't as stiff as they should be.
A quick bar in the joints at the bottom will tell you if the bottom arms etc. need doing. On Ebay you ca get pattern parts for them all really for a full front end set. At that mileage I would be.
Old 29th November 2011, 04:29 PM
Or maybe the anti-roll-bar links too, I had a rattle over bumpy roads and both needed done, not expensive. But at 180k, could well be needing a whole set of arms
Old 30th November 2011, 09:49 AM
Thanks, I'll probably take it somewhere with a lift. It all looks ok just lying on my drive with a torch.
Old 30th November 2011, 11:26 AM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
Interested to know what you find. I have the same rattle/knock as you describe with brand new drop/C-links fitted.
Bex
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 30th November 2011, 06:42 PM
Oh dear Bex, I just ordered some C-links.
I will let you know how I get on, everything else looks ok, so I suspect something internal to the airspring damper assembly if symptoms persist.
Old 30th November 2011, 09:11 PM
A8L Chick's Avatar
Pretty sure mine isn't the actual strut itself, just doesn't sound like that at all, I can also feel the slight rattle/knock from both the passenger and driver footwells, can you???
Bex
Old 1st December 2011, 02:31 AM
are you sure its not the exhaust knocking somewhere if you can feel it in so many places Bex?
Old 1st December 2011, 05:24 AM
Broken cat would rattle and that might be the source of engine problems you are having as well.
Old 17th December 2011, 07:53 PM
Well, I managed to get around to fitting these today using the Elsa manuals and some FEBI parts from ebay <£50/pr.
Problem solved, feels somewhat tighter and refined at the front too, the old ones where shot and bushings delaminated.
Thanks for all the tips. I hope you find yours is something simple (and cheap) A8Chick.
