Old 30th November 2011, 04:57 PM
tonyt102's Avatar
tonyt102 tonyt102 is offline
Default Brembo upgrade question
Hi all.
Found these on eBay and not sure if they'll fit my car? I have a 1999 face lift S8 with the different style brakes. Looking at getting the rear door cards and rear shelf for a blind upgrade too.
http://www.ebay.co.uk/itm/BREAKING-A...item3a6d55678b
Thanks in advance.
Old 30th November 2011, 05:39 PM
Is that listing not for the hub?
Old 30th November 2011, 05:46 PM
tonyt102's Avatar
Oops. He actually has the calipers listed elsewhere. I was looking at the hubs aswell as I thought I might have to change these too.
I've just been out to look and it appears that I have the 323mm versions so not sure if its a case of just a caliper and rotor or hub too?
Old 1st December 2011, 07:25 AM
I'm pretty sure it's a straight forward bolt on job, the caliper carriers should be the same.
So you'll just need the calipers and discs. What wheels do you have?
Old 1st December 2011, 11:14 AM
Zip's Avatar
Zip Zip is offline
Thumbs up
....and that's a VERY good price as well for the callipers.
Zip
Old 1st December 2011, 12:51 PM
tonyt102's Avatar
Thanks for the reply.
I have 17" Avus, should be ok shouldn't it?
Old 1st December 2011, 02:42 PM
Zip's Avatar
Zip Zip is offline
pretty sure they WON'T fit under 17s, but others may know
Old 1st December 2011, 02:57 PM
tonyt102's Avatar
I was under the impression that these were fitted to later S8's which had the Avus alloys??? Could be wrong. I'm looking to get some FE alloys anyway but they're had to come by at a reasonable price.
Old 1st December 2011, 03:24 PM
The hubs may need changed, some of the early FL models had the same hubs as PF so these wouldn't fit. Do you know which brakes you have just now? There are a couple of options (the codes from the build sticker should tell you).
Old 1st December 2011, 03:31 PM
tonyt102's Avatar
The hubs are aluminum if that makes a difference? I'll have to look at the codes when I get home.
