Old 19th December 2011, 09:22 AM
sutherland sutherland is offline
Default Warm up time on a 4.0 TDI
After years of driving petrol Audi V8s, I recently switched to a 4.0 TDI. So far it's been a good experience, but I am wondering how long these engines normally take to war up? Yesterday, I had to drive for about 10 miles and 17 minutes before the guage reached 90C whereas my petrol A8s were at normal temperature fairly quickly even when it is freezing outside. I also do not recall other diesel cars taking such a long time to warm up.
Is this normal behaviour for a 4.0 TDI or do I have a lazy thermostat or something?
Old 19th December 2011, 10:31 AM
Do you have a Webasto supplementary heater?
If you're not sure, look for a regulatory sticker on the underside of the bonnet. If you have, it may be worth checking this is running from cold starts, the diesel exhaust outlet is in the plastic sump tray and should issue a light smoke you can see easily with a torch at night.
My 3.0V6TDI is also too slow to warm up, tried two thermostats and later today will try another temp sender.
Old 19th December 2011, 11:57 AM
Modern diesels are a nightmare to warm up... Our XC90 takes about a week (or so it feels).
Old 19th December 2011, 03:16 PM
Maybe I haven't been observant enough driving other diesels, but this one seemed to take a long time. Having said that, I've no experience of an XC90 diesel.
My car does have a Webasto sticker, so I'll have a look as you suggest. Perhaps there will also be a fault code if that is not operating.
Old 19th December 2011, 03:58 PM
Snaga Snaga is offline
HIya, i have an 04 4.0tdi and have alwaysbeen pleasntly surpised how quickly she warms up. Will have a look tomorrow when i go out.
Audi A8 4.0TDI D3
Old 19th December 2011, 05:11 PM
Yes, it has quite good diagnostics and if it registers a fault, such as over temp will lock out for safety until an adaptation of value 01 is done to a certain channel (07 IIRC)
Old 19th December 2011, 08:48 PM
Bout 12 mins this evening to get to 90c. Warm from fans after bout 4mins.
Audi A8 4.0TDI D3
