Old 3rd January 2012, 03:17 PM
Zip's Avatar
Zip Zip is offline
Question Passenger side washer jet 'blocked'?
Any ideas how I get to the tubing that supplies the passenger side jet? I'm sure it's blocked (ish). Not obvious how to free up / disconnect to flush out.
Ta,
Zip
Old 3rd January 2012, 03:29 PM
The trick I normally use (and have successfully on my S8) is to block the other jets with sewing pins (or safety pins) pushed in firmly then operate the washer to flush it through.
Old 3rd January 2012, 06:32 PM
Iyole Iyole is offline
If U remove the covers behind the air box at the top seam of the drivers side fender you,ll find a T piece with a one way valve and sieve that gets blocked...
Give it a good clen and rather suck the gunk out of the one pipe....if necessary..... That sounds Gross.....
But I find it works better than blowing in the pipe.
2002 S8 D2 F/L
