Old 6th January 2012, 04:09 PM
Default More gearbox problems
As some of you may know, I've just bought James' (mkoneman) S8, but I've got gearbox problems within 48 hours of picking it up.
This morning when I selected reverse gear, all the gear indicator panel lit up (I think that indicates 'safe mode'?). But after a couple of restarts and a run to the end of the drive, it was fine again and did the 30 plus mile trip to work with no problems.
But when I left work tonight, the gear indicator panel was fine, but it wouldn't change up from 1st gear, either automatically or on the tip. Again, after a short run and a couple of restarts, all was fine again for the journey home.
What on earth is going on? And is this an expensive fix?
