D2 - Lights Headlights, xenons, foglights. Everything outside the car that glows |
As the subject says chaps.
No indicators, have hazards and main beam. Haven't noticed anything else not working. Can't see a fuse labelled indicators, both fuses marked hazards seem OK. What's most likely switch or flasher unit (wherever that lives)? TIA Bob |
It's a D2?
Relay is either on the right hand side of driver footwell, or in the relays under the passenger's feet, can't remember which.
Yes it's a D2 S8 (2002 I think)
The relay you are looking for has 191 stamped on the top of it and is in the relay box in the passenger footwell. The Audi part number should be 1H0 953 227 (or 431 953 231 if you have a towbar). Give us a call if you need a replacement
Thanks very much for the info. Hopefully it will stop the car pretending to be a BMW
