Old 22nd March 2012, 11:30 AM
johnds8 johnds8 is offline
Default Seatbelt height adjuster
Hi,
My drivers side seatbelt height adjuster doesn't work. You can hear the motor working but no movement.
Is this a common fault and is it as simple as a linkage coming off/loose etc?
Not a real problem really but it's about the only thing wrong with the car and want to sort it.
Just looking for some advice before pulling the trim off.
TIA
John
Old 22nd March 2012, 11:32 AM
Not a problem I've heard of before, should be easy to pop the trim off and see though
Old 22nd March 2012, 01:14 PM
david@a8parts david@a8parts is offline
Director at A8 Parts
The motor is situated low down behind the lower B pillar trim and is connected to the upper height adjustnment mechanism by a cable with a plastic cog on either end. The plastic cogs can wear out as they get brittle and their teeth fall off! If you have motor noise then it almost certainly is the drive mechanism that has failed.
Very easy to swap over too just be careful not to damage the upper part of the top B pillar trim removing it there are some tricky little screws which means you need to remove the upper roof side trim first to get at them
We have them in stock so give us a call!
At Work to Break:
2001 TT 8N 1.8T Quattro with a loud exhaust!
2000 A8 D2 3.7Q Non Sport Ming Blue
1999 A8 D2 4.2Q Non Sport Santorin Blue
2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather
2001 A2 1.4 TDi
2006 A6 C6 2.4 Quattro Avant Canyon Red
At Work to Drive:
1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch
1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash
2008 Fiesta Sportvan x2
2002 Transit 2.4 LWB
2007 VW Crafter Recovery Truck
2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart
2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses.
At Work to Hire:
4x 6 Berth Sunlight Motorhomes
Old 22nd March 2012, 06:58 PM
Originally Posted by david@a8parts View Post
...can wear out as they get brittle and their teeth fall off!
I know just how it feels!
Sorry David - I'm sure it worked OK when I had it, but I've taken that trim off before on the old A8 if you need a hand.
Old 22nd March 2012, 07:55 PM
think there is more than your teeth going your mixing up your Davids I think
Old 22nd March 2012, 09:11 PM
That post had me wondering too..... I thought that the David at A8 Parts would kinda know how to get the trim off.
Old 22nd March 2012, 10:26 PM
Sounds like "The Laird" is going a tad doo-lally like his colleague in a similarly big stately home, Lord Bath
Old 23rd March 2012, 05:39 AM
Oh, yes, that was a bit of a senior moment wasn't it?
Note to self - read the thread properly!
Old 23rd March 2012, 11:51 AM
Default ,
Cheers for the info guys!
John
