Old 30th April 2012, 02:26 PM
RanjS8 RanjS8 is offline
Default Wanted timing tool kit Audi s8 40 valve engine
I m looking to buy the timing tool kit for the 40 valve s8 engine...so could someone tell me where I can get one from thanks
Ranj
07525747277
Old 30th April 2012, 02:45 PM
Nollywood's Avatar
Ranj
07525747277
Quite a few on eBay, here's one:
http://www.ebay.co.uk/itm/VW-AUDI-Ca...item3a73474043
Old 30th April 2012, 02:53 PM
Thats for a 2004 though, so D3..... I've not looked, but I'd be very surprised if the D3 and D2 engines used the same tools....
Old 30th April 2012, 03:02 PM
Nollywood's Avatar
I've always done timing belt jobs without the tool, so can't say for sure. But I assumed the early non-FSI-engined D3 V8 used the same cam/crank lock, but I'm probably wrong.
Back to the bay then!
Old 30th April 2012, 03:27 PM
Nollywood's Avatar
I've just confirmed - the cam / crank locking tool for timing belt replacement are the same for facelift D2 V8 and pre-FSI D3 V8.
Old 30th April 2012, 04:39 PM
I bought these from Germany, only used locking tool to check timing, have not used other tools as I didnt need to change the belt.
I didnt get the sprocket-puller tool, I think he has it listed in his ebay shop.
http://www.ebay.co.uk/itm/VW-AUDI-S6...item43991234a9
http://www.ebay.co.uk/itm/VW-Audi-Vi...item43a59a1d9c
http://www.ebay.co.uk/itm/Audi-VW-V6...item587ff94f76
http://www.ebay.co.uk/itm/VW-Audi-Zw...item5885621f67
I think this is the sprocket puller
http://www.ebay.co.uk/itm/VW-Audi-Ab...item58826d4881
You will also need T40009 ecentric pulley adjuster, I cant see that one listed in his ebay shop
Old 1st May 2012, 08:13 AM
Default Cambelt tools
Thanks guys my plan to pull an repair an s8 engine is slowly coming together...judging by the fact that blauparts.com charge about 350 deposit for their timing tool kit...I expected to pay quite a lot but those prices above are quite reasonable.
Old 1st May 2012, 10:19 AM
richyb66 richyb66 is offline
Hi Ranj,
I've got the timing tools for the 40v engine that I bought when I did my cambelt, you can borrow it if you want. I'm in Tamworth, work in South Brum and I'm occasionally in Cov.
Let me know if this is any help.
