Old 22nd January 2009, 12:52 PM
A8 Doc A8 Doc is offline
Default Removing Rear Seats
To remove the rear seats simply put your hands under the bench where it meets the chassis and tug up each side on the left and right of the bench.
Do not pull the seat up too far as it has electrical connections underneath it, these will need to be unplugged before removing the bench completely.
Once the bench is removed you can use a Size 16 socket to undo the rear backrests. Again electrical connections are present so be careful.
