Old 22nd January 2009, 12:55 PM
A8 Doc A8 Doc is offline
Default Removing Boot Liners
To remove the boot liners:
1) Remove the centre carpet covering the spare wheel
2) Using a flathead screwdriver undo the plastic screws over the battery and the small cubby hole on the left.
3) Using a Torx screwdriver undo the Torx screws where the luggage net hooks into the floor
4) Remove the rubber seal around the boot
5) Pop off the plastic cover around the boot latch
6) Gently prise off the side panels from the boot by pulling them. They are just press fitted in.
Reinstall is the reverse of removal.
Old 13th April 2010, 12:20 PM
sloss's Avatar
sloss sloss is offline
How do I remove the boot lid liner to get at the rear lights on my '08 A8 Facelift?
They have condensation in them which I want to remove and seal them properly.
I've been told Audi don't accept this as a warranty job but stand to be corrected....
Stew
