Old 20th May 2012, 08:09 PM
Default Replacing screenwash nozzles
My S8 has no squirt whatsoever on the drivers side, and the passenger side was poor. These were flagged up as failures on its recent MOT.
So, looking at it in a bit more detail, the pipe starts at the drivers side, Tees off for the drivers squirter, then carries on to the passenger side. if there is water on the passenger side, but nothing on the drivers, the jets must be blocked....
I could try and clear them, but i have a spare car I'm using for spares at the moment, so its easiest to rob one from that.
Heres a photo of the pipework. The red circle is where the power connectors are for the heating element in the jets. Seems the drivers and passengers side have the same length cable, so the drivers one is cable tied up to lose the length. Also worth noting on both my cars the cables had frayed and come out of the nozzle, so the heating wouldnt work. Might explain why I've never really seen the heated nozzles on D2's having much effect.
Here is a photo of the nozzle, with its quite lengthy cable, with 2 pin connector on the end:
Here is a side on shot of the nozzle. The pipe connector is a push on / push off at the rear. Elsawin suggests you have to remove the whole wiper valance to get access to these, but actually, if you pop the pipe off the rear, then press the plastic tab at the front (arrowed) with a flat blade screwdriver it will come loose and pop up....
And a full side on shot showing the cables. There should be one at the top too, the brown wire, which has come off on this one....
Once I swapped over the nozzles, and sorted an overly-tight cable tie on the pipe, the drivers was perfect and pressure was up on the passenger side too...
ID:	3505   Click image for larger version
ID:	3506   Click image for larger version
ID:	3507   Click image for larger version
Old 20th May 2012, 08:24 PM
Mine were a bit ineffective recently so I used an old trick to flush them out.
First I got some largeish safety pins from SWMBO's collection.
Then I used a thin sewing pin to poke through the hole in the metal ball of each jet to make sure they were as clear as could be; pushed well in and lots of wiggling to disturb crud behind.
I plugged all the jets with the larger pins - pushed in FIRMLY - leaving one open. Then just squirt!
Work around the jets in turn to clear them all.
If you're not confident the needles won't be pushed out get a "trusty assistant" (or 2) to hold them in place!
Old 20th May 2012, 09:30 PM
Yes, pins are a worthwhile option in the first instance.... I'm just a little odd in that a spare set of nozzles was easier to lay my hands on at the time than sewing kit
Old 23rd May 2012, 07:40 AM
i have this on the D3 also, i would like the misting ones off a newer moddel as the 2 streams just dont seem to get the correct coverage and there is a massive delay in when i ask them to squirt to the time where they actually do squirt ? air in the line maybe
Old 23rd May 2012, 08:54 AM
Zip's Avatar
Zip Zip is offline
My Saab used to have small non return valves in the tubes to keep the system 'primed' with washer fluid with a rubber diaphragm that used to perish over time. Something similar in the D3s?
zip
Old 23rd May 2012, 09:26 AM
Even Halfords sell them for just a couple of quid: http://www.halfords.com/webapp/wcs/s...ource=shopping
