D2 - Interior Seats, dashboards, plastics, ventilation everything inside the cabin |
Thread Tools
Display Modes
Hi Guys, just figured out that this actually works(just assumed it didn't) it works perfectly going up, but when put down again... The motor powering it keeps running(like its not aware that it should stop) only way to stop it is to kill the ignition... Once the car is turned back on everything is fine, so killing the ignition sort of resets the motor.
Any fix for this? Mostly I'm just a sucker for details and hates to have neat gadgets that does not work fully. My rear window is tinted black... So the curtain itself does not really block more sun out(as like 98% is blocked already by the black tint) Could just be nice if it worked as intended. Cheers /Jake
![]() ![]() Audi A8 4.2 quattro D2 94' - THE CARRIAGE Audi A4 1.6 B5 95' - THE LADY IN RED Opel Kadett 1,2 C 77' - THE CASKET |
is it making a ticking noise? if it is then the gear on the motor has stripped.this was something i still needed to find a fix for on my stolen car.it is listed on elsa win on how to replace the motor so i assume you can just buy a new motor and gearbox for it.but i never got around to finding out.
![]() Quote:
then its the gear inside the motor housing that has stripped teeth at the point where it would be when closed. mine had done the same thing.i did notice that audi sells the motor so you might be able to get the whole housing and gear aswel.
