Old 24th May 2012, 07:58 PM
SyncroS8 SyncroS8 is offline
Default It's dead...
Hmmm... Driving home today, 2 miles from home... the S8 splutters and dies.
Tank still showing 1/4 tank. No faults.
It cranks over fine, tries to start but won't.
Added another 8 litres of petrol, no difference.
It'll start and run on Easy start but dies as soon as you stop spraying.
I'm thinking that the fuel pump has died.
MG
Old 24th May 2012, 08:22 PM
bugger! sorry to hear that. Luckily the Yanks come through again.
http://forums.quattroworld.com/a8/msgs/21098.phtml
there are more fuel pump posts in that FAQ.
Old 24th May 2012, 08:34 PM
graynada graynada is offline
Same happened to me and it was the pump. I put a 12v feed straight on the pump contacts and it wouldn't run just to confirm it. Audi only do the whole pump assembly for lots of pounds but new pump was about £150 delivered from other sources.
Old 24th May 2012, 08:59 PM
RanjS8 RanjS8 is offline
Default Fuel pump
Changing the fuel pump isn't too bad...making sure it is seated properly is the tricky bit....cos u can't see what u r doing....just be patient and take ur time...or try getting someone to watch from the fuel level sender hole??? Possibly...
Old 24th May 2012, 09:35 PM
47p2's Avatar
47p2 47p2 is offline
My Merc had the same symptoms and it turned out to be the CPS
Nite Blue 3.0L SE Quattro
Old 24th May 2012, 10:29 PM
Just confirmed that it's the fuel pump.
I managed to get some life from it by hard wiring the feed, checking that the pump had that same feed at the pump connector and then hitting the pump resulted in some noises and enough pressure to start the engine.
MG
Old 24th May 2012, 10:33 PM
This is also why my engine has been running lean!
MG
Old 25th May 2012, 08:04 AM
Reseating wsa a worry for me too but the twice I pulled it it reseated no problems. Just carry a can of fuel and beaware around 1/4 tank you could have a moment
I found alot of the seals were huge when I stripped mine down. A couple of days drying out and they were back to where the should be. I'm guessing the rubber absorbes petrold and makes em grow
Strangly Audi don't sell the pump only but only sell a complete seal kit for changing the pump only and complete refurbishment of thge pump assembly. You can't get individual seals which is a bit annoying and expensive.
Old 26th May 2012, 07:29 AM
On it's way to Leeds.
MG
Old 27th May 2012, 10:25 AM
Nollywood's Avatar
I like the color.
