Old 2nd June 2012, 10:44 PM
RanjS8 RanjS8 is offline
Default how to remove intake manifold 40v
How do remove the the intake manifold off the engine???
I have remove 4 torx bolts either side and the thing just wont budge....i have a mallet ready to hit if need be....but i d rather use finesse if possible...so any advice would be much appreciated.
Old 3rd June 2012, 01:37 AM
47p2's Avatar
47p2 47p2 is offline
Check underneath, there must be more bolts hiding somewhere. It should fall off when loosened
Nite Blue 3.0L SE Quattro
Old 5th June 2012, 12:26 PM
Default Hex bolts not the torx bolts
Turns out the torx bolts hold the upper part of the manifold to the lower part. To remove the intake manifold you have to undo the hex bolts...there are 7 each side and the intake manifold pretty much drops off.
There are vaccuum pipes you have to detach and the fuel pipes...but other than this comes off fairly easy.
