Old 6th June 2012, 08:17 AM
Default Wipers just stopped working....
....and it's p*****g down! They were on intermittent wipe on the way to work and then stopped altogether. Not had chance to have a look yet, but there was no warning - they worked fine until they didn't!
Old 6th June 2012, 09:06 AM
Maybe you disturbed the 25amp fuse (No. 10 on fuse carrier 1) when replacing the other fuse? (presumably Fuse No.3 on fuse carrier 5? - make up mirror/lock release for boot lid/courtesy lights/interior monitor, cent locking switch/memory for morror and seat positions).
Old 6th June 2012, 10:16 AM
Amanda Amanda is offline
Will be the wiper motor as they have a habit of failing you can rebuild them if you are that way inclined or pay TPS instead!!
Old 6th June 2012, 10:26 AM
James replaced the one in your car a while back, Jim, the motors came from A8 Parts. Buy new from TPS, especially if you're keeping it.
Old 6th June 2012, 10:48 AM
I had to replace the one in my 2.8 A8, but it at least gave me some warning and juddered a bit. This one just stopped. So did James replace it with a used motor from A8 Parts? Seems strange that it failed so quickly? Do I need a part number for a motor from TPS?
Old 6th June 2012, 11:03 AM
47p2's Avatar
47p2 47p2 is offline
TPS will look up the part number for you
Nite Blue 3.0L SE Quattro
Old 6th June 2012, 11:07 AM
My PF would do it now and again... Does it work on full speed? Mine would come back to life after a vigorous spraying with WD40 (what doesn't?)
Old 6th June 2012, 11:45 AM
david@a8parts david@a8parts is offline
Director at A8 Parts
Part number is 4D2 955 113 B for the motor on its own. Looks like James bought the motor from us 2 years ago, but even so please give us a call and we can work out a deal on a replacement for you if you decide not to buy brand new.
At Work to Break:
2001 TT 8N 1.8T Quattro with a loud exhaust!
2000 A8 D2 3.7Q Non Sport Ming Blue
1999 A8 D2 4.2Q Non Sport Santorin Blue
2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather
2001 A2 1.4 TDi
2006 A6 C6 2.4 Quattro Avant Canyon Red
At Work to Drive:
1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch
1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash
2008 Fiesta Sportvan x2
2002 Transit 2.4 LWB
2007 VW Crafter Recovery Truck
2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart
2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses.
At Work to Hire:
4x 6 Berth Sunlight Motorhomes
Old 6th June 2012, 12:18 PM
seems to me a bit coincidental with the other problems which would tend to suggest fuse problem other than motor failure as suddenly as that
Old 6th June 2012, 12:32 PM
Just went out to see if it was a fuse, so I could call TPS if I needed a motor....
......and they're working fine!
No hesitation or juddering, just working as usual.
