Old 6th June 2012, 04:26 PM
Exclamation Urgent help required please
sorry to jack the wrong area but i need this badly
http://forum.a8parts.co.uk/showthrea...1512#post41512
W12 has spat all the coolant out and i have clients to pick up on friad need help asap please
Old 6th June 2012, 05:13 PM
sloss's Avatar
sloss sloss is offline
The white smoke points to 'burning' water which is usually a head gasket.
Big job on that engine I'd think. No easy fix if it is.
Diagnosis is first as you need to find which bank. Try plugs off one at a time to see if you can find the dodgy cylinder(s) ie no white smoke or still runs the same, just don't run it too long or it could burn head/block interface.
Good luck!
Old 6th June 2012, 05:19 PM
its a new engine and the smoke is not coming out of the exhaust its from under the bonnet the water is coming out as quick as i can get it in there with a hose pipe its coming out the bottom just as fast, sounds like a hose that has burst or something, if its a head gasket then i dont think the water would flow out as quick as what it is
well .... i hope
Old 6th June 2012, 05:28 PM
sloss's Avatar
I read the referenced thread and though it was white out the exhaust.
It doesn't look as if it's a head gasket with your latest explanation. Could be water pump or a simple hose burst.
You need to pinpoint exactly where it seems to be coming from then look at a drawing and see what part of the water works is nearest.
I't not a common engine so it might take a while for someone who 'knows' to come along!
Old 6th June 2012, 06:07 PM
Amanda Amanda is offline
White smoke ESP if theres lots equally a water leak have you checked rad / water pump and hoses?
Old 6th June 2012, 06:30 PM
47p2's Avatar
47p2 47p2 is offline
Sound like it has popped a hose
Nite Blue 3.0L SE Quattro
Old 6th June 2012, 06:43 PM
If it's going out that fast my bet would be that whoever put in new engine did not secure one of the hoses properly and it has come off. Seen it before and must admit did it once myself after head gasket job. Forgot to tighten clip on one of houses and it came off some 2 weeks later.
Old 6th June 2012, 07:08 PM
47p2's Avatar
That was my thinking
Old 6th June 2012, 07:28 PM
SilverS8 SilverS8 is offline
Will this help?
Name:	W12 Engine 1.JPG
ID:	3814   Click image for larger version
Name:	W12 Engine 2.JPG
ID:	3815   Click image for larger version
Name:	W12 Engine 3.JPG
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 6th June 2012, 09:53 PM
very big help thank you for the images anything like that if you can pdf it and email it me that would be a big help daviesbike@yahoo.co.uk
many thanks
