Old 9th June 2012, 02:06 PM
mannyo mannyo is offline
Default Code D2 central locking for alarm beep
Right, so have VCDS which I currently only use to scan and fix errors on my A8.
I would like to program the central locking to beep when the car is locked / unlocked in addition to the currently flashing indicators. The current controller coding is: 13130 , so could someone advise what needs to be added to enable the lock / unlock beep.
With my previous car altering settings was easy, as it had full Canbus and you could use the long code helper, but seemingly not with the A8.
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D17
Coding: 13130
Shop #: WSC 00000
VCID: 428F4E3B641F
Manny
Past
