Old 6th July 2012, 11:49 AM
Default For engine lovers
Some facts on the 14 cylinder version:
Total engine weight: 2300 tons (The crankshaft alone weighs 300 tons.)
Length: 89 feet
Height: 44 feet
Maximum power: 108,920 hp at 102 rpm
Maximum torque: 5,608,312 lb/ft at 102rpm
Source:http://forums.bimmerclassics.com/bim...el-engine.html
Name:	Engine at the door (1).jpg
Old 6th July 2012, 11:51 AM
Ship engine?
Old 6th July 2012, 12:19 PM
Ship engine?
No, buyer collect due to size
Old 6th July 2012, 12:22 PM
Iyole Iyole is offline
Yup..... large container ships....
And this be the Turbo
2002 S8 D2 F/L
Old 6th July 2012, 12:30 PM
Ship engine?
No, this is going in the back of brand new 2 seater S8 model. They had to put it in the back because of visibility problem with it sticking out of bonnet. Rumour has it that it solves nose heavy under-steer problem as well.
Old 6th July 2012, 12:51 PM
sloss's Avatar
sloss sloss is offline
Unfortunately it just won't rev out so a quick overtake is a little scary
Dunno if you can chip it though....
Old 6th July 2012, 01:29 PM
Variable ratio gearbox let's you drive full power at any speed. Always 102rpm at crank- variable speed at wheels.
Somebody already retrofitted it to golf with slight visibility issue
Old 6th July 2012, 01:51 PM
Surely that's only the 6-cylinder version popped into the golf?
For an 8 you'd want the larger engine, at least 8 or 10 cylinders. Or for enthusiasts 14 cylinders and 100,000hp would be "handy".
Diesel-electric would probably work better than CVT though.
Old 6th July 2012, 07:26 PM
Thats gotta have a tad of Turbo Lag
Old 7th July 2012, 07:22 AM
47p2's Avatar
47p2 47p2 is offline
This engine for me
Nite Blue 3.0L SE Quattro
