Old 12th July 2012, 06:29 AM
sloss's Avatar
sloss sloss is offline
Default New Boots
Got a pair of Eagle F1 Asymetrics fitted yesterday. First impressions are good. Road noise is fine, however they are affected by white lines, I haven't tried ultimate grip yet as I think they need a few hundred miles on them first.
The last pair of Dunlops Sports only did 16k and I'm not sore on tyres.
We shall see....
ID:	4076   Click image for larger version
Old 12th July 2012, 06:30 AM
Well, that's half of an Ian Dury album anyway.
Old 12th July 2012, 07:00 AM
Night Train's Avatar
What about the rock and roll......
err, That was a single, not an album wasn't it
Other vehicles
Oh Yes....... The '98 PF S8!
Old 12th July 2012, 07:18 AM
47p2's Avatar
47p2 47p2 is offline
Make sure the pressures are spot on if it's tram-lining
Nite Blue 3.0L SE Quattro
Old 12th July 2012, 07:36 AM
sloss's Avatar
The Tyre Fitter guy took the pressures from the fuel flap.
He cleaned up the wheel tyre bead lands thoroughly and was very careful to protect the rims with s slipper type arrangement on the tyre machine.
New valve carefully fitted, ie he did not use the rim as a fulcrum.
He knew the car needed to be put into Jack Mode as well, he was very professional unlike a KwikFit spotty youth
Old 12th July 2012, 07:47 AM
47p2's Avatar
Best check your pressures with your own gauge, you'll probably find that all pressures vary by a couple of pounds
Old 12th July 2012, 08:22 AM
Nope, it was an album
http://www.amazon.co.uk/product-revi...owViewpoints=1
Old 12th July 2012, 09:08 PM
sorry, I wasn't too clear on that.......
I was referring to a certain track from that iconic album [& having seen the great man live (a very long time ago)] that was also released as a single
Other vehicles
Old 16th July 2012, 08:58 PM
Bushido Bushido is offline
Whats "Jack mode" all about then????
Old 16th July 2012, 09:01 PM
Not a concern on a D2 - On the D3 you have air suspension which will go nuts trying to level itself when you jack one corner up - unless you put it in Jacking mode, then it will just let it be...
