Old 13th July 2012, 08:54 PM
Somerandomguy's Avatar
Default Transmission mount question
Im showing a short to plus on the right gearbox mount, but am having trouble with the part number and etka.
I have got the part number from the mount today (as i was changing the transmission fluid!) which is 4e0399151bg, but etka says this was dropped in 2004 with no replacement.
When i look up the mount based on my car (2004 3.0 diesel, ASB/GZV) it lists a rubber bushing rather than mount and the picture is nothing like the valve, as it does just look like a rubber bush (pn 4ep399151dh but pretty pricey). Etka only seems to show these active mounts on the bigger engines, 4.0 and above (pn 4e0399151dd), any suggestions? Do i go for the DD version or, stick to what etka says and hope it just a bad picture and description? Has anyone else changed one of these mounts?
Old 15th July 2012, 10:37 AM
If you have a full copy of EKTA you can use the part number lookup facility to see which part nimber replaced it. sometimes on older cars there are 2 or 3 iterations!
Old 15th July 2012, 02:18 PM
It might be good if you could show a few screen grabs to show folk how to do that mike?
Old 15th July 2012, 03:52 PM
I *think* I have a full version of ETKA, when i search by the old part number it does list it, but says that it was dropped in 2004 and does not list a replacement.
Usually he pictures are pretty accirate, but they don't look like my valve.
