Old 23rd July 2012, 05:58 PM
Karstad Karstad is offline
Default Foglight error
On my audi A8 d2 3.3 TDI the fog lights just stopped working one day. The fuse on the passenger side is ok, aswell as the bulbs. What is the problem?
When i push the foglight switch nothing happens, its dead. not even a light comes on inside dashboard.
Any ideas?
Old 23rd July 2012, 06:05 PM
relay or wiring broken?
Old 23rd July 2012, 06:10 PM
don't think its the wiring because it happened so fast. i started the engine, switched one the lights and hit the foglight switch. The green light came on for less then a second and haven't worked since.
Where can i find the relay?
Old 23rd July 2012, 10:18 PM
Its on the relay board (item 2 on the pic shown) which is under a wooden cover plate in the passenger footwell
Relay is part No 8D0907701A
control unit for fog lights and rear fog light / relay location/code no.:
3+8/397 /
Name:	Relay board.png
Old 24th July 2012, 06:30 AM
found it, thanks
how do i check if its broken?
Old 24th July 2012, 07:48 AM
Does anyone know how to get the foglight switch out?
think the switch is broken since the rear foglight switch works.
Old 24th July 2012, 10:01 AM
its just a slow lever job with a trim tool or screwdriver to each side of the switch and it will pop out - but make sure you protect the wood carefully
Name:	Fog Light Switch.png
Old 24th July 2012, 10:09 AM
david@a8parts david@a8parts is offline
Director at A8 Parts
You might find it easier to prise out the centre vent above - it is just pushed in so comes out easily without the need to undo anything - use a flat blade butter knife or similar and work it out a centimetre at a time at each end. Once you have it out there should be just enough cable on the vent to settle it upside down on the dashboard then you can simply push the switches out from behind the wood trim.
It might sound a long winded way but the switches arent that easy to get out from the front in our experience
At Work to Break:
2001 TT 8N 1.8T Quattro with a loud exhaust!
2000 A8 D2 3.7Q Non Sport Ming Blue
1999 A8 D2 4.2Q Non Sport Santorin Blue
2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather
2001 A2 1.4 TDi
2006 A6 C6 2.4 Quattro Avant Canyon Red
At Work to Drive:
1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch
1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash
2008 Fiesta Sportvan x2
2002 Transit 2.4 LWB
2007 VW Crafter Recovery Truck
2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart
2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses.
At Work to Hire:
4x 6 Berth Sunlight Motorhomes
Old 24th July 2012, 11:37 AM
i removed the vent and it was no problem, thanks.
Nothing wrong with the switch tho I'm all out of ideas now..
Old 24th July 2012, 07:29 PM
sloss's Avatar
sloss sloss is offline
Use a multi meter to find where you have 12volts or not as the case may be.
As you have the switch out how did you test it?
How did you check the relay?
I'd start at the foglamps themselves - there should be 12v across the 2 wires with ign on, switch on and sidelights on.
