Old 4th August 2012, 05:33 PM
MAM MAM is offline
Default Bluetooth - addition
I have a D3 with a Motorola phone in the armrest that uses Bluetooth, but the Bluetooth seems restricted to that phone.
For me to upgrade to Bluetooth that will connect to my iPhone, do I just need to buy a Bluetooth unit 4E0862335 and swap it for the installed unit?
If I do just swap, do I need to get someone to register it with the software? Are there any things to watch out for on compatibility or am I safe with any unit with the right part code?
Deep Green 2006 '56' A8 4.2 SE, B&O & Exclusive Interior
Extended Aluminium, Oak Sepia Wooden Trim, Extended Leather
Green Exclusive Dual Colour, Heated Comfort Leather Interior
Green Alcantara Headlining, Pillars, Rear Shelf, Door Inserts
Green Trimmed Mats, Seatbelts, Steering Wheel, Centre Armrests
DAB, Freeview, ACC, 4-Zone Climate, Soft Close, Electric Blinds
Old 4th August 2012, 09:28 PM
Straight swap...
http://forum.a8parts.co.uk/showthread.php?t=908
is my writeup... You can leave or remove the old motorola handset in the centre. if you take it away, it leaves a hole, but some duct tape sorts that, and you could always retrofit a USB charger into the lighter feed for the rear and run it up there (what I did anyway).
Old 5th August 2012, 12:39 PM
MAM MAM is offline
I will try to pick up a unit - they occasionally seem to go for a low price on ebay.
Old 12th October 2012, 06:37 PM
MAM MAM is offline
Am I right to assume that I do not need the antenna, microphone or wiring kit and can just buy the module on its own.
Old 12th October 2012, 06:40 PM
you dont need the antenna but you will need the microphone, installs in the centre above your head, so you need to take some trim of to get it in
Old 12th October 2012, 07:01 PM
MAM MAM is offline
I already have the daft phone in the armrest, will that microphone not do the job?
Old 12th October 2012, 07:04 PM
yes sorry, it will, should be a simple change then
Old 12th October 2012, 07:11 PM
MAM MAM is offline
Great, thanks.
Old 13th October 2012, 09:43 PM
what you're looking to do is exactly my write up. no extra bits needed.
Old 16th October 2012, 08:23 PM
MAM MAM is offline
Excellent. Have just bought a unit - when I get it next week I will look at installing.
Is it fully plug and play, or may I need to get the MMI upgraded? I am not on 5570.
