Old 3rd September 2012, 04:31 PM
kal_ay's Avatar
kal_ay kal_ay is offline
Default Brake upgrade advice
Hi guys after a bit of a spirited drive recently in the S8 i noticed brake fade,and crapped myself basically,so was wondering if i were to upgrade what route would be best?Ceramic?
Or is there any other options?cheeRS.
2002 D2 S8 Misano Red
1996 Volvo 850R Estate Red
2013 Mercedes C63 AMG (taxi)
1991 Lotus Carlton Imperial Green
Old 3rd September 2012, 06:18 PM
thebluewhale's Avatar
Why don't you upgrade the pads first?
See if you can get a set of Ferrodo DS2500 pads. Not seen a bad review of them yet. It's what I'll be fitting when the new calipers go on my car.
If the new pads don't work I suppose ceramics are the next step but fook me they're expensive.
You could always look aftermarket. AP Racing and such may do conversion kits.
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
Old 3rd September 2012, 08:05 PM
You want the 390MM Six Piston Brembo RS6 V10 setup I had fitted to my car today - A8 Parts have the kit for sale, and it is bolt on to the D3 as far as I'm aware. The brakes DO NOT fade at all, and will stand the car on it's nose if need be. Before you splash out on all of that though - Try this:
Racing brake fluid, Try ATE Racing Blue or Motul RBF600.
Pads, The Ferodoo DS2500 as mentioned are good, Carbotech pads even better. What is the brake setup on the D3 S8 currently?
Old 3rd September 2012, 08:28 PM
Pics, they just fit under my 19'' wheels!
Old 3rd September 2012, 09:25 PM
kal_ay's Avatar
Thumbs down
Cheers guys,Singh looking sexy there mate .
I'm not sure what set ups on mine just standard.Calipers look smaller than yours though.
Old 3rd September 2012, 09:30 PM
Theres a viscious rumour going around that youve had those fitted because I'm driving your car at ADI !!!
Old 3rd September 2012, 09:43 PM
Pop some ATE Racing Blue fluid in and see how you get on mate, the brake upgrade is £2k+. If you're still not happy, more aggressive pads and then like me, the full shabaz.
Old 3rd September 2012, 10:01 PM
kal_ay's Avatar
Thanks mate will start with fluid and pads first
