Old 28th September 2012, 04:16 PM
tallon tallon is offline
Default Eliminate gear selector for paddles?
I want to eliminate my gear selector altogether and use steering wheel paddles and using tiptronic shifting only. Is this possible in the A8? Even if the gear selector is hidden under the column that would be fine, do I still need actuators to put the car in park, drive, reverse? How would that work?
This is not going on the airbag steering wheel just an after market one. I don't have to mess with the audi console, steering wheel, etc.
Old 28th September 2012, 05:00 PM
I'd say it's 'possible', but you'd need a good bit of wiring
Old 28th September 2012, 06:29 PM
I figured about the wiring, I wouldn't mind that.. but what kind of actuator could set Park, reverse and drive? Or is there another way of doing it?
Old 28th September 2012, 06:35 PM
Well presumably something like the current jaguar range uses, it works quite well (having driven them all).
There's a rotary pop-up knob/dial that you just rotate to PRNDS as required:
Then it's auto or flappy paddles if you want to use them.
