Old 1st October 2012, 07:48 AM
Default Guess what I finished this weekend
With a little help from A8 Parts again, lots of earlier help from Richard and the main component from Gordon's scrap S8. Here's a clue - phhhhhhh
Old 1st October 2012, 08:06 AM
fixed your bust boot locking?!
Old 1st October 2012, 08:17 AM
I wish!
Old 1st October 2012, 08:18 AM
solar roof install finished? running out of ideas if its not that!
Old 1st October 2012, 08:26 AM
Yes, give that man a prize!
The clue is the sound of the fan (a bit like an asmatic mouse) just about running in the feeble Scottish sunshine.
I got the correct relay from A8 Parts, swapped out the standard relay and waited for a break in the rain to check that it was working!
Old 1st October 2012, 08:31 AM
Glad to hear it - we can compare "phhhhh's" at the next meet - assuming that I've fixed all the aircon/drainage leaks by then, and have replaced all the panels properly
Old 1st October 2012, 08:32 AM
It depends; mine was whooshing steadily about 20 hours a day back in June up in Wester Ross and Sutherland.
Old 1st October 2012, 12:19 PM
Yaay. At long last, it's complete
Old 1st October 2012, 12:35 PM
I really must investigate the packages of bits to do mine at some point, now we know from Ian's informative post what wiring is required
Are there only 1 of these relays required in cars with solar roofs, or are there a number that can be acquired from any D2?
Old 1st October 2012, 12:46 PM
There is just one relay for the solar sunroof which replaces the 'standard' relay for the aircon fans.
If you already have a sun roof, you need the solar roof itself, two runners/rails with the electrical connections, lots of wires, the relay and Richard (or similarly competent auto electrician).
