Thread Tools
Display Modes
Pretty much as the title suggests really. Car now clicking when accelerating.
![]() 3.0 TDI with a gazillion miles on the clock. Many thanks. Becci
07 Silver D3 A/S8L Quattro ![]() ![]() Last edited by A8L Chick; 6th October 2012 at 07:12 PM. Reason: iPhone bloody auto correct |
Is the noise there all the time or only after a t̶h̶r̶a̶s̶h̶i̶n̶g̶
![]() Could it be a diesel knock due to a faulty injector, or is it more metallic? If metallic it could be any number of things that would require investigation Hydraulic tappets, cam-shaft, timing chains, manifold flaps all spring to mind Best have it looked at soon as possible
. Nite Blue 3.0L SE Quattro |
See if it does it when cold tomorrow and report back.
Can you record it with a camera? Does it do it when stood still just revving it? |
Ok, on initial investigation it's not doing it from cold now. It sounded "tappety" to my relatively untrained ears.
Going to see what she's like after being Wayne up an taken for a normal more sedate drive ;-) Thanks so far guys, I nearly cried earlier. :'-(
07 Silver D3 A/S8L Quattro ![]() ![]() |
Ok, I may have jumped the gun, upon driving her, the engine braking caused the "tapping" to start up again, and the car feels like she's tryin to "drive" when I'm stationary. She actually stalled in P.
Would I be right in thinking she's over fuelling for to a faulty injector on the drivers side?? It also. Sounds like a belt is slipping when the car is unhappy about stopping too???
These are weird symptoms. I have never read of anything exactly like this.
These injectors are electro piezo and usually very quiet, in fact because of their design, I don't see how they could be noisy compared to the older type. Any smoke or bad smell from the exhaust? If you could test with VCDS Engine measuring blocks 14-17 on the engine it will show smooth running mg/S for each cylinder and if any is over +/-2.99 (typical good condition is +/-0.5) then injector is not operating correctly. I wouldn't use it until you can have it looked at for fear of causing damage. Good luck ![]() |
She's getting plugged in today. Snap on computer is the best I can find
![]() Car really doesn't sound happy. ![]() Not checked for smoke, there was a funny smell after the drive home but didn't recognise it to describe it. ![]() I'll try to update again later.
Turned out to be pretty fatal and not top end as originally thought. Fine gold filings in my oil are pointing to be bearings.
Pulling the engine apart later.... ![]()
Oh Lord
![]() Make sure you wear gloves! ![]() |
