Old 10th October 2012, 09:12 AM
david@a8parts david@a8parts is offline
Director at A8 Parts
Default Gearbox Brain in BMW v AUDI
I was out driving at the weekend in my Mum's BMW 330Ci Auto. Now, I have noticed on many other occasions when driving this car that the gearbox ECU is far more intelligent than any Audi Auto I have driven but the damn thing seems to get more intelligent each time I drive it !
The Audi boxes are fairly clever - if you put it in sport mode it will hold the gears briefly when you release the accelerator (so long as you do it quickly enough) and it will learn your style and if you are in the mood to press on it will work with you. However, the BMW box is on another level. Accelerate hard and release and it will not change up until you accelerate again. Accelerate into a corner and it will not change gear while you are cornering. And something I have never experienced in an audi, and it is so obvious in the BMW, is the engine braking. Coming down Sutton Bank (quite steep) on Sunday in no rush at all I started the downhill and gently pressed the brake pedal. The box shifted down into 3rd to assist me to slow down (cool). Then as I continued to lightly press the brake the speed of the car continued to increase so the box dropped down into 2nd (excellent!) and I travelled down the hill hardly needing to use the brakes at all just as you would in a manual car. How clever.
Now, annoyingly, the BMW box is ZF and the gearbox controller is Bosch so identical set up to Audi - if the W12 controller had this level of intelligence it would make a real difference; I wonder if I can send it on a training course to BMW....
At Work to Break:
2001 TT 8N 1.8T Quattro with a loud exhaust!
2000 A8 D2 3.7Q Non Sport Ming Blue
1999 A8 D2 4.2Q Non Sport Santorin Blue
2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather
2001 A2 1.4 TDi
2006 A6 C6 2.4 Quattro Avant Canyon Red
At Work to Drive:
1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch
1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash
2008 Fiesta Sportvan x2
2002 Transit 2.4 LWB
2007 VW Crafter Recovery Truck
2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart
2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses.
At Work to Hire:
4x 6 Berth Sunlight Motorhomes
Old 10th October 2012, 09:21 AM
OMG... Has Amar hacked your account....
Old 10th October 2012, 09:24 AM
Oh god David, youre gonna start off Amar now lol.
The A7 has quite a smart S-tronic box that uses online services to tell exactly where you are and anticipates corners and bends ahead and holds a gear instead of changing up where it normally would but its got a fair way to go to be as clever as that one lol
Old 10th October 2012, 09:37 AM
My father was a BMW driver, but he left home one day without any indication at all
Old 10th October 2012, 09:49 AM
I'm quite sure my antique S8 does that, you do have to be applying the brakes going downhill but not slowing down. Pretty sure it's documented in the drivers manual too.
And I noticed on the D3 I had a while back that it automatically applies the brakes too if cruise is on and you accelerate downhill due to gravity, though I suspect that's quite standard nowadays.
Old 10th October 2012, 10:39 AM
Here I am.
They don't call them ''The Ultimate Driving Machine'' for nothin'.
Old 12th October 2012, 09:29 AM
It was always my understanding (and experience - as short as it is) that the D2 box changes down when going downhill when you apply the brakes. The manual does indeed confirm that. page 69 - Dynamic shift programme (DSP). It states "on downhill gradients, the gearbox shifts down into a lower gear when the driver presses the brake pedal. This makes use of the braking effect of the engine withour having to change down manually."
Old 12th October 2012, 09:37 AM
Though having recode my TCU I don't know if that still applies as some of the documentation I've read suggests DSP is now off with what I've done. I'll try it sometime...
Old 12th October 2012, 11:01 AM
A8 Doc A8 Doc is offline
Try your S8 TCU in your W12. Got to be worth it for testing of course.
Old 15th October 2012, 02:21 PM
Here I am.
go back under your rock Amar haha
and david you should know better than to post that hear tut tut indeed haha
no on a more interesting note i think the TCU Re map really dose make a massive difference if you have a re map
