Old 10th October 2012, 10:27 AM
A8Jas A8Jas is offline
Default D3 Headlight goes pink!
I've had a quick scan of the forums and think my nearside healdight bulb is on it's way out as it's colour shifting. There has been a very intermittent problem with it cutting out going up the short term car park ramp at heathrow but only then (adaptive light issues?) So I'm going to change the bulbs first and have found some reasonable instructions on how to do this.
But I need to make sure I'm getting the correct bulbs first, am I right in assuming all D3 had Xenons? (what are bi-xenons then?) Can I order any D2S bulb off ebay? Web comments seem to recommend 6000K colour temp but are there any other things to check - prices seem to go from £3.99 to £139!
Jas
Old 10th October 2012, 12:06 PM
Yes, any D2S should be OK. My current ones were 6000K and £12.99 a pair and they are 95-100% as good at the £89 Philips 85122+ I used before.
How easy they are depends on engine configuration, but the one behind the airbox was easy enough with a mirror and torch, but after 1 hour of struggling on my power steering tank side, I removed the wheel arch liner and did it from underneath which was much easier and that only took 20-30 mins start to finish after that. The first time, I disconnected the power steering tank pipe and removed it as the instructions I had said to do that, but I didn't the second time.
Bi-xenon is when the main beam and dip share the outer lamp and a shield moves up inside the lamp for main beam. The inner lamp is used for DRL and has a PY21W bulb on - 2006 and 5xLEDS 2006 - on. If you don't have bi-xenon the inner lamp is main beam. Changing the bulb is the same and it is still a D2S.
Old 10th October 2012, 12:10 PM
Jas
For what its worth I've just put 6000K D2S's in my Xenons on the D2 as one was feinter than the other, and very happy with the colour / brightness
I went with we-sell-hids on ebay and a pair of 2 cost £13.95 with free postage. The genuine phillips ones were £30 each cheapest at hids4u.co.uk so I thought I would try these and see how I get on both quality and length of service wise
Old 10th October 2012, 12:27 PM
Brilliant thanks, My main beam is the same light as dipped (outer) so that's bi-xenons then. I will try the DS2s from Ebay and might do the DRLs as well as I'm sure they aren't LEDs as they colour is too yellow and dim... I have them turned of at the moment. Will go for the 6000k versions too.
Old 10th October 2012, 01:04 PM
ainarssems ainarssems is online now
Having tried aftermarket HID's in 4300k, 5000k and 6000k with the Chinese aftermarket HID kit I have to say that 4300K is the way to go. 5000k is rare to find, 6000k is a bit too blue to my taste, has less visible light output and get even more blue with the age. 4300k provide the most visible light and still does not look yellow. OEM are 4300k as well. But I guess it's also down to personal preference.
