Old 24th October 2012, 11:08 AM
Question Wanted Wheel spacers +++
Im after a second hand or new if any one has some wheels spacers ether 2 or a set of 4 what ever any one has got
the wheels on the car now look to much tucked into the arch on the rear
also will i need different wheel bolts if i have a spacer ?
many thanks
Old 24th October 2012, 11:15 AM
also forgot to ask if it would be better with 20mm spacers or 15mm ? and do i go all round or just the rear ?
http://www.ebay.co.uk/itm/Audi-20mm-...7d46305&_uhb=1
found this but id like some cheaper
Old 24th October 2012, 11:57 AM
Iyole Iyole is offline
I have 15" on my S..... I wouldn't go wider than that IMO.
Starts putting to much additional strain on Wheel Bearings and Suspension.
You will need to get longer Wheel Nuts.
2002 S8 D2 F/L
Old 24th October 2012, 12:09 PM
If you get the H&R trak+ style ones like THESE then they bolt to your current holes with bolts provided and then your standard bolts can be used.
If you need longer bolts then Ive used THESE and THESE
Old 24th October 2012, 05:31 PM
mmm very good thanks guys
the H&R ones look good to me
