Old 28th November 2012, 07:48 AM
Default Rear bumper insecure - how is it fixed
I noticed that my rear bumper wasn't aligned properly, just a subtle difference between the gaps to the bodywork and bootlid between left and right.
No marks suggesting any impact, but who knows the cause.....
Anyway, on checking just now I found that the nearside was somewhat loose and would move a few mm up and down.
Can any one describe the mountings and how to access them, and is there something obvious that could have come or worked loose? I was wiggling it in the general area of the exhaust.
Old 28th November 2012, 08:34 AM
If you still have the plastics on the under side drop them at the rear, bumper is held on by 2 off socket cheese headed bolts that run through the impact pistons.
See the pic below, you can see where the impact piston goes where the 3 holes are, piston is on the floor under car and the bolts that hold bumper to piston you can just see in the bottom of the pic.
Name:	towbar fitting.jpg
Old 28th November 2012, 09:51 AM
OK thanks, sound simple enough if I can get access - weather isn't ideal at present.
The nearside bumper moves in and out and up and down a few mm so I hope it's just that those bolts are loose and nothing worse. Can't think why though....
Old 28th November 2012, 09:52 AM
Elsaweb has good exploded views of PF/FL bumpers and fixings. See
http://elsaweb.spaghetticoder.org/na...4465/63/16209/
Old 28th November 2012, 04:30 PM
there's a reinforcing bar across the inside of the bumper which is what bolts on to the car. The bumper is clipped on to this, so could be that this is the issue.
Old 28th November 2012, 04:52 PM
It feels like it's just the bumper that's moving; nothing more solid seems loose behind it.
I need to get hold of my mate down the road who has a proper trolley jack etc.
Old 29th November 2012, 10:04 AM
I guess that requires removing the bumper totally to find out what is wrong and rectify it.
Old 29th November 2012, 11:29 AM
You won't need a trolly jack to take the bumper off, it's a nice and easy one 2 bolts and it's away
Old 29th November 2012, 01:47 PM
Yep.. it's easy to get underneath and get it off.. just watch the rear wheel arch liners as you pull it back.
Old 29th November 2012, 08:43 PM
Single Piece Rear Bumper - Exploded View
Adjusting Rear Bumper
