Old 24th December 2012, 06:54 PM
darrenjoe90's Avatar
Default Parking brake help
my left rear parking brake it stuck on with lots of red lights on my dash and lots of bleeps if i try to move. can anybody help ?
Audi S8 Phantom Black
Old 24th December 2012, 07:12 PM
Have you done a scan Darren?
Could be a wire broken or the connector corroded on the EPB but if its stuck on then not sure if that can cause it to not release
If not then you could try a replacement seal kit on the EPB like Bex did to save replacing calipers at their larger cost
Old 24th December 2012, 08:42 PM
david@a8parts david@a8parts is offline
Director at A8 Parts
If you just need to get moving for the time being Darren there is an emergency caliper rewind tool in the tool kit. Use the small end to remove the motor from the caliper and then the larger end to rotate the mechanism to release the pads from the disk.
As far as I know you can do this and still drive the car safely (without use of the parking brake) but dont quote me on it !
At Work to Break:
2001 TT 8N 1.8T Quattro with a loud exhaust!
2000 A8 D2 3.7Q Non Sport Ming Blue
1999 A8 D2 4.2Q Non Sport Santorin Blue
2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather
2001 A2 1.4 TDi
2006 A6 C6 2.4 Quattro Avant Canyon Red
At Work to Drive:
1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch
1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash
2008 Fiesta Sportvan x2
2002 Transit 2.4 LWB
2007 VW Crafter Recovery Truck
2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart
2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses.
At Work to Hire:
4x 6 Berth Sunlight Motorhomes
Old 25th December 2012, 10:51 AM
Check the connector on the top too.. Mine did that and it was just a little loose and some crap had gotten in during the winter, just needed cleaned up and reseated.
Old 25th December 2012, 11:57 AM
Mine too, last February. The dealership had replaced the connector/cable under warranty ~2 years before and made a mess of it and was not watertight.
Old 14th March 2014, 07:41 PM
a8starr a8starr is offline
So my parking brake decided to not release tonight. Whilst idling the engine is still able to pull the car forward but warning lights flashing. The parking brake motor is making a sound and when flicking upwards it locks everything tight. Flicking down seems to half release the PB and car can move forward at idle but it feels like something is still grabbing the discs.
Questions
1. Does the rear parking brake lock up both rear wheels or just one?
2. Could water ingress or dirt in the connections cause weak motor function and therefore not disengage the callipers completely?
3. Are my callipers shot?
4. I have VCDS (bit of a newbie still) would this help me out at all?
I have a jack and axel stands in the garage also.
Any help would me much appreciated as I am not able to drive anywhere.
Old 14th March 2014, 09:06 PM
Yes, it operates independantly on bothe rear wheels.
Make sure the noise comes from both sides, if not check the quiet side.
If both make a noise, I would also check for sticking piston a few of us have had that. Mine was dirty and corroded due to torn dust boot, but just needed a clean up and a new seal kit.
Old 14th March 2014, 09:10 PM
Thanks for the reply snapdragon.
Here are my fault codes. First scan in 53. Parking brake revealed 5 faults. Cleared the faults then on 1 appeared.
Friday,14,March,2014,21:56:36:41609
VCDS Version: Release 12.12.2 (x64)
Address 53: Parking Brake Labels: 4E0-910-801.clb
Control Module Part Number: 4E0 910 801 A HW: 4E0 907 801
Component and/or Version: EPB AV1C1010 H01 1010
Software Coding: 0000221
Work Shop Code: WSC 02313 785 00200
VCID: 1D3108
5 Faults Found:
02432 - Supply Voltage for Left Parking Brake Motor (V282)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 197
Mileage: 138544 km
Time Indication: 0
Date: 2014.02.24
Time: 17:42:05
Freeze Frame:
Voltage: 11.90 V
Count: 92
02429 - Right Parking Brake Motor (V283) Clamping Force Not Reached
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 193
Mileage: 138312 km
Time Indication: 0
Date: 2014.02.22
Time: 23:41:47
Freeze Frame:
Voltage: 12.63 V
Count: 15
02431 - Right Parking Brake Motor (V283) Resistance to Movement
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00110011
Fault Priority: 3
Fault Frequency: 33
Reset counter: 228
Mileage: 138264 km
Time Indication: 0
Date: 2014.02.22
Time: 12:19:46
Freeze Frame:
Voltage: 13.66 V
Count: 19
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 197
Mileage: 138152 km
Time Indication: 0
Date: 2014.02.18
Time: 18:02:23
Freeze Frame:
Voltage: 11.80 V
Count: 93
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11111100
Fault Priority: 1
Fault Frequency: 15
Reset counter: 188
Mileage: 137816 km
Time Indication: 0
Date: 2014.02.15
Time: 09:58:50
Freeze Frame:
Voltage: 13.04 V
Count: 87
scan 2 after first codes cleared
Friday,14,March,2014,21:59:09:41609
VCID: 1D310
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 16
Reset counter: 188
Mileage: 137816 km
Time Indication: 0
Date: 2014.02.15
Time: 09:58:50
Freeze Frame:
Voltage: 13.04 V
Count: 87
Old 15th March 2014, 03:48 PM
Looks like the right EPB motor isn't happy. Not sure how servicable they are, but might be something easy. Make sure the connectors are on properly and clean.
Old 15th March 2014, 08:27 PM
Had the AA round to help.
Turns out the rear driver side calliper is sticking a bit.
We discovered this by jacking up both rear wheels and spinning them.
Its sticking less than last night because charging the battery helped and we were able to roll the car by foot.. Took it for a spin and a bit of heat still got generated.
So I do plan to check the connections.
Is it OK just to disconnect the PB cable and cable to calliper in order to clean them?
