Old 8th January 2013, 10:09 AM
Default OBD port location on FL D2
I'm sure the info is around somewhere, but I've had a good search and can't find it.
Where is the OBD port on a Facelift D2?
On my PF S8 it's under the front ashtray, but I'm sure I read something that said it was moved......
Old 8th January 2013, 10:29 AM
It's below the dash to the right of the steering column as you're sat in the driving seat
Old 8th January 2013, 10:43 AM
Thanks.
Old 8th January 2013, 10:54 AM
Iyole Iyole is offline
Right next to the Bonnet release handle....
2002 S8 D2 F/L
Old 7th February 2013, 03:37 PM
Well now I actually have an FL D2 I've just got around to running VCDS.
Found an assortment of things, of unknown vintage, so I've cleared them and will see what reappears...
The cleared faults included several (explainable) Alarm triggers plus:
17977 - Cruise Control Switch (E45): Implausible Signal P1569 - 35-10 - - - Intermittent (hardly a surprise )
16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - - Intermittent (Cylinders 2 & 4 listed specifically, I'll see if that reappears)
01119 - Gear Recognition Signal 35-10 - - - Intermittent (ABS section)
00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent (did have a flat battery at one point)
Couple of oddities though:
1: HVAC 1 Fault Found:
00734 - Potentiometer in Central Vent (G142) 30-00 - Open or Short to Plus
This wouldn't clear.
I took a guess that this "could" relate to the hot/cold thumbwheel by the 3 top centre vents so wiggled it "aggressively" and tried again. It cleared.
2: Immobilizer No Faults Found
or DTCs not supported by controller or a communication error ocurred
This communication error was there only sometimes when I queried the controller individually. Is it something to worry about?
Old 7th February 2013, 05:09 PM
Just for future reference, it is still under the ashtray on some early 99-00 facelift models.
Old 7th February 2013, 06:21 PM
I wouldn't worry unduly - probably most of those are old error codes not properly cleared. Mine was full of them when it went into a garage (have the printout somewhere and its a about 7 pages!) but after clearing none have come back
Old 8th February 2013, 05:48 AM
They can't be too old. Most codes clear if fault has not appeared after 30 ignition on/off cycles apart from airbags and possibly some other safety features.
That points to vacuum leak, bad MAF or as 2 and 4 are on the same bank possibly bad lambda or valve timing slightly off between banks.
most likely dirty ABS sensor or ring
FL does not have separate immobilizer so you need to scan instrument cluster.
Old 8th February 2013, 01:50 PM
OK thanks. I've noticed some odd behaviour and lack of power when starting off from cold, maybe related?
When I first move off it often seems rather jumpy almost as if I'm pumping the throttle (I'm not) and when pulling out of a junction I've experienced a lot less power than expected, but only within the first minute or so from cold.
It still accelerates, but sluggishly (for an S8).
Once warmed up it's totally fine. Any ideas?
Old 8th February 2013, 02:33 PM
Sounds like one or couple cylinders not working properly(or one bank), misfiring. If it's only from cold it could be coil packs, dodgy cambelt tensioner shock absorber or oil retention valves causing oil to leak out of chain tensioner when parked up. Maybe low compression in some cylinders when cold.
