Can we not approach Audi or tps as a club to work out a deal to keep these classics on the road? ( that's if they are interested some manufactures aren't).
I don't fancy converting mine to a manual I like it as a auto! Whould the D3 box fit? Which I believe is a 6 speed auto? If its more reliable? Just a thought cheers Dave
2002 S8 silver with black half leather 2000 d2 S8 in Racing green pearl, RS4 manual gearbox, 2003 A4 avant TDi 1997 Volvo V40 2.0T 1992 Mazda eunos v spec 1976 Reliant Kitten 1965 Porsche 911 |
The D3 tip will physically bolt up to the D2 S8 motor, and you can get away with custom trans mounts, but that's where the differences will become apparent.
The ZF6HP26 has different dimensions to the D2's ZF5HP19/24. So your axles and driveshaft won't fit. The TCU for the D3 is also very different to that of the D2, and won't communicate with your ECU. My advice? If your trans is fine, just do what you can to keep her going - fluid and filter service. If it's gone bust, then a rebuild or replacement with a factory rebuilt exchange is your only option. Good luck!
2006 Audi A8 D3 Quattro Sport 4.2 TDI - Silver, Family Oil Burner. 2000 Audi A4 Quattro Sport 2.5 TDI - Santorin Blue, S8-Powered DTM Race Car Build In Progress. 2000 Audi A4 Quattro Sport 2.8 30V - Pelican Blue, RS4 Widebody, D3 4.2 01E, High-Spec B5 Build In Progress. |
Hi Hollywood thanks for your advice I expected the propshaft and don't see that as a big problem I've had them made before for around £100
Drive shafts are a little more expensive I think I've paid less than £400 last time for custom Half shafts made in USA and delivered in 10 days The TCU unit and ECU would be tricky, but maybe not impossible I have a engine management specialist friend who may be able to help. I've not actually asked him! CanBus could be the problem!!!! And I've not looked into the final drive ratio yet! No I've not thought of everything I'm just trying to see if its alternative solution Dave
Hmmmmm There is no where in the uk to get the gearbox rebuilt
??? one of our members is currently having his rebuilt at a ZF Agent up here in snow free Glasgow
Audi S8 2015, Daytona Grey |
![]() Quote:
I meant to add "uprated" ![]() |
![]() Quote:
But already, I can see this costing way more than an 01E 6-speed manual conversion.
![]() Quote:
![]() Im quite friendly with the guys there. If someone can give me a serial number off their 'box (alternatively i can get mine, but will need to wait til i get a shot of a ramp) i can certainly ask the question! |
Yes there is, and you know there is. Sometimes, you amaze me.
![]() Anyway, nobody here, just like myself, are probably not hot on spending £5/6/7k up rating gearboxes, the D2's run half the C5 torque we do. By all means post the specs for your new box and TC however, as many will find it interesting.
2009 Audi RS 6 Saloon V10 - 420mm Ceramics, Keyless, Soft Close, Adaptive Cruise, Glass Sunroof, Blinds, Twin Pane & UV, Freeview & DAB, High Beam Assist, MTM bits, Audi Exclusive Bits, MRC, Milltek, GYEF1 ASY2's, Bluetooth streaming music to AMI mod - 753 PS/1021 NM 2016 Audi S3 Saloon, Sepang, S-Tronic - B&O, Tech Pack etc... Company Car 1995 Audi A8 4.2 V8 quattro Sport - Bose, Solar, Blinds Last edited by Singh; 21st January 2013 at 09:11 AM. |
Custom axles can be built in the UK.
Yes they certainly can but last time I bought some shafts, Quaife wanted £800 For custom shafts and I got some from moser engineering in the states for less than £400 cheers Dave
