Old 9th March 2013, 10:28 AM
Sir WIll Sir WIll is offline
Default Bluetoothy in a D2 - Quick Questrion
Gents,
2002 D2 with RNS D and Bose.
Do I need an Autoleads cable if I go out and buy a standard Parrot kit?
Old 9th March 2013, 10:55 AM
mannyo mannyo is offline
Chances are the parrot kit will not work with the bose setup at all. You need a kit you can feed into the RNS-D phone input, the parrot expects normal speaker level outputs from the headunit that the bose setup does not have.
Manny
Past
Old 9th March 2013, 11:20 AM
Thanks, I think I will just go to the pub then
Old 9th March 2013, 11:21 AM
Pub sounds like a good idea.
Manny
Past
Old 9th March 2013, 11:28 AM
So, just following on from this, what options do I have on my FL D2 for phone addition/integration at "reasonable" cost.
RNS-D, NO Bose, NO phone prep.
I have a selection of handsets and smartphones available (though no cradles) and normally use a separate SIM (legacy of the antique Nokia 3110 factory install in the PF) that my family etc. know the number of.
Favourite handset would probably be Nokia 6310i (I have 2 plus a 6210) as I often use this when travelling as the battery literally lasts for weeks without a charge.
Old 9th March 2013, 01:04 PM
I've got a Parrot and RNS-D and Bose. So has Brian
Old 9th March 2013, 02:00 PM
I say, straight install or have to buy any adapters/ cables or magic pixie dust?
Old 9th March 2013, 04:11 PM
I have non Bose, and sorry cant help with the question as the Parrot was already fitted when I got the car, it is a great piece of kit though
Would be an option for you too HP though would obviously need a phone with Bluetooth capability
Old 10th March 2013, 01:21 PM
Bose and Parrot in a D2 does work - I too have this. Installation a bit more complicated with the Bose (or so I was told by the guys who fitted it...), but works very well when done.
