Old 1st April 2013, 04:14 PM
sarg sarg is offline
Default D3 S8 buying advice
Now my Boxster has gone to its new carer, I am starting to shortlist my next car, at the moment it's a not a very short list but the D3 S8 is certainly on it, as well as C6 S6.
So, having not owned a D3 before, what should I be looking for?
Rear brake calipers
Suspension troubles
Electrical gremlins
Any other common gripes?
There are a couple of S8s I quite like. One is a 2007/07 basic spec with 60k miles at £17k, the other a 2008/58 facelift car with ACC and ceramics with 51k miles at £23k. Also a 2006 S6 Avant standard spec with 70k miles at £14k. Others in the running are an E60 M5, E90 335i/335d or a RRS/Touareg/Q7/X5
I know the cosmetic differences for facelift, but what else was 'improved'?
The sat nav changes to HDD based I know, but is this a dealer only option for updating, as opposed to the 'back-up' DVD updates available.
If I do buy another Audi, VCDS or similar will be an essential purchase, which is the best one to get and what else do I need to be able to read and translate codes? Anyone tried one of the Bluetooth transmitters that plugs in the port and sends the info live to your smartphone?
Ceramic brakes: I know they can be removed, sold on and replaced with standard brakes, but what is required? Is it simply reaplcement discs and pads, or do other components also need changing, such as calipers, hubs, etc?
Can't find any S8s with B&O currently (excluding the silly season priced one with Oscar Goldman - 28k) so is the Bose good enough without waiting for a B&O car?
Any suggestions for who to use for a PPI? Cras in question are in Cardiff, High Wycombe and Oxford - anyone in those areas with VCDS that could help?
Lastly, one of the negatives against another Audi is the lack of a decent local specialist - I used to use RSD in Daventry but was never overely confident in them, nor were their prices especially cheap, Revo are also in Daventry but only do performance tuning I think (?) so anyone got any other ideas in the Midlands - Ranj, Amar, Ainarss?
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 1st April 2013, 04:50 PM
The best Audi specialist around is 30 mins from you.
http://www.mrctuning.com/
Good job too, as unlike the local BMW dealers here, the Audi ones have been terrible every chance I've given them.
Unit 20 do PPI inspections and will travel.
You can get a brand new M5 at 0% with massive deposit contribution from BMW at the moment. That's what I'd do if I didn't love my RS6 so much. Look into a new M5.
Old 1st April 2013, 04:53 PM
MRC are pretty close, thanks for that Amar, have heard before they are very good, didn't realise where they are. Do they do routine maintenance and servicing as well as tuning though?
F10 M5 ain't gonna happen, it's a big jump from spending 20k to 65k mate, interest free or not!
Old 1st April 2013, 05:03 PM
Consider Ian's B8 S4, after MRC have tuned them it'll do 0-60 in 3.38 secs and 11.7 1/4 mile, that was on their development car too, the final product is much quicker. It's only about £1.5kish too, so nothing crazy. Watch it destroy the Revo one here:
http://youtu.be/ZAYFcSPQnCc
If you do go for a D3 S8, Milltek it up! I don't know much more about them apart from a standard one floored it near me recently and it sounded sublime.
Old 1st April 2013, 05:13 PM
yup, the B8 S4 should also be on the not so shortlist, must be an auto though for SWMBO, the better mpg has its attractions, not so sure of the sound from that clip though. I do quite fancy another 8, above all else I love this forum, my favourite place to spend coffee breaks, especially compared to boxa.net which seems to be getting frequented by chavs a lot now that the prices have brought them into reach, even if they can't actually afford to run them as well as buy them
The two things I disliked most about the Boxster:
1. 6 cylinders engines sound great, but they're not V8s (okay, nor is the S8/M5 but you get my point)
2. It needed revs to make the most of it, I want something much much torquier
Old 1st April 2013, 05:53 PM
Hdd nav can be updated without dealer input but does require vcds to get the mmi into service mode iirc. Its then a case of a firmware update which the car assumes is a software handshake with Audi Germany. Doddle to do with the right kit - easier than RNS-e anyway!
Old 1st April 2013, 07:30 PM
richardracer richardracer is offline
Default S8 D3 buying advice
Hi Sarg,
I have run my S8 D3 for 30k miles in 11 months now. My service costs for normal consumables/labour have been £500 for 60k service and £250 for intermediate longlife service (after 17k miles) with my local indie and genuine Audi parts to protect my warranty. I paid £700 for new Audi steel brake discs and pads all round, also indie fitted. Tyres last 12k to 15k and cost £250 to £300 per corner for Bridgestone (OE) or Yokahama. 4 wheel laser alignment is critical, failure to keep it straight wipes out tyres in less than 1000 miles (outside edges).
I have had problems fixed under warranty (Warrantywise best available) with power steering pump/hoses, rear electric brake caliper motors, suspension compressor, relay and level sensors. Good warranty highly recommended because these parts and labour are not cheap. I used Slough Audi for warranty work but be aware that labour rates are £120/hour plus VAT, so choose right warranty labour level.
I get 22mpg for 85 mph cruise on motorway 150 miles per day using super unleaded. Even driving like a nun at 70 mph only gets me up to 23 mpg, so don't expect much more. Looning/town driving can get below 15 mpg with ease. It does not like ordinary unleaded, low speed low throttle misfire sometimes.
I have a genuine VCDS and would not cope without it. I paid just uner £300 for it from UK importer. You get a cable with dongle built in. Software comes on disc, but latest version can be downloaded from VCDS site (Ross-Tech).
I have B&O stereo and have loved it. I fitted DAB radio and already had ipod connectivity with Dension 500 system, so music choice is excellent. It is a sublime place to listen for my regular 2 hour commute daily. I also value the quiet exhaust (standard not Milltek) so I can hear the sound stage/separation of teh B&O. Unbelievable for inside a car and better than my home music system!
The 2G MMI is easily updated with the correct discs. I did it in around 3 hours including bluetooth messing around. The standard phone reception is affected by double glazing I think. Signal strength is not as food as my BMW 740 was using same phone. I lose signal regularly along the M4 at Swindon and Newbury. I am looking into an Rsap adaptor which uses the external car aerial and "hijacks" the SIM card. Also looking for better phone sound quality. In car phone cradle makes no difference to signal strength or sound quality, basically a charger platform, since it uses bluetooth to talk to MMI.
The silver paint quality is excellent in my case. I spent £1000 sorting out some cosmetics/refurbing wheels and detailing in my first 3 months. My detailer said it was as hard as nails when he detailed it last year. Comes up very shiny when it is washed at weekends. The interior is a nice place to be. I have the 2 tone trim with silver/grey panels inset into black leather with leather on most panels up to windscreen height, then alcantara from windows upwards.
If you are interested in trying my car or discussing my experiences, drop me a PM. I live in Bracknell and work in Chippenham. Happy to help, they are great cars if you can afford the running costs (fuel, tyres) and have a warranty company to support the unexpected.
Good luck in your search
Richardracer
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 1st April 2013, 09:12 PM
If you can see corrosion or delamination of the black surround of the rear window (visible from outside) the rear heated screen may be broken.
Audi Stafford replaced mine under warranty with me contributing £350.
It appears to be a common problem
Old 1st April 2013, 09:46 PM
Excellent & detailed reply Richard
Old 1st April 2013, 09:55 PM
Nope - HDD 3G Sat Nav came in 2009 across Audi range - Not at all related to 2008 D3 facelift, which gave things like revised mirrors with indicators, square fog lights, lipped boot lid, chrome starter button, chrome trims on door pockets and things like advanced key/dab/xenons/DRL as standard. To be honest, unless you're looking at poverty spec motors, the facelift isnt worth paying a big premium for imo.
Yes, Bose is absolutely fine. Until you hear B&O in action, and then you suddenly feel like you've short changed yourself. I was mulling (and still am) the C6 S6 - Prices have fallen, and good spec ones can be found, but B&O isnt even an option - in which case Bose is the best you can hope for, and it will be fine. In an S8 though, I'd (personally) hang out for B&O unless the car was otherwise irresistebly cheap/well specced.
