Old 14th April 2013, 05:14 PM
Mattyb Mattyb is offline
Default URGENT! Glow plug heater warning light flashing
Im driving home from london to newcastle and the glow plug light has started flashing, engine keeps cutting out. Has anyone got any suggestings please?
Old 14th April 2013, 05:25 PM
Also the the car will accelerate if im gentle with the pedal, but if i push to accelerate quickly it cuts out.
Old 14th April 2013, 05:31 PM
Sounds like fuel supply problem, could be simple thing like blocked fuel filter b ut could also be failing fuel pump. Hard to tell without plugging it in.
Old 14th April 2013, 05:55 PM
So i need to get it on vcds
Thanks for your help
Old 18th April 2013, 07:11 AM
Well i managed to get her home, took 5 hours.
Bought mysef a vcds too, so im going to plug it in today and see if i can find out whats wrong.
Do you know if i buy a new fuel pump and fit it myself, will it need to be coded or will it just work.
Old 18th April 2013, 09:35 AM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
Change the fuel filter...that's what mine was
Could be a number of things but that's one of the cheaper options... go for OEM
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 18th April 2013, 03:47 PM
im going to change the fuel filter now, iv just had it on vcds and got these fault codes
Thursday,18,April,2013,16:40:35:41965
VCDS Version: Release 11.11.5
Control Module Part Number: 4E0 910 401 J HW: 4E0 907 401 B
Component and/or Version: 3.0L V6TDI G000AG 0020
Software Coding: 0011973
Work Shop Code: WSC 02313 785 00200
VCID: 224B3171FD6C1C08178
8 Faults Found:
18279 - Transmission Mount Valve 2 (N263)
P1871 - 001 - Short to Plus
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Voltage: 11.93 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
Temperature: 61.2°C
19591 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached - Intermittent
Freeze Frame:
RPM: 756 /min
Torque: 93.6 Nm
Speed: 0.0 km/h
Voltage: 13.60 V
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
Duty Cycle: 80.9 %
Temperature: 87.3°C
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.86 V
Bin. Bits: 00101100
Torque: 1035.3 Nm
Torque: 89.7 Nm
16619 - Boost Pressure
P0235 - 001 - Regulation Range not Reached - MIL ON
Freeze Frame:
RPM: 2205 /min
Torque: 214.5 Nm
Speed: 122.1 km/h
Absolute Pres.: 1530.0 mbar
Absolute Pres.: 765.0 mbar
Mass Air / Rev.: 564.0 mg/str
Temperature: 22.5°C
Duty Cycle: 69.4 %
17471 - Fuel Pressure Regulation
P1063 - 001 - Control Range Not Reached - Intermittent
Freeze Frame:
RPM: 2079 /min
Torque: 206.7 Nm
Speed: 117.6 km/h
Duty Cycle: 1.0 %
Voltage: 13.68 V
Pressure: 546.7 bar
Duty Cycle: 42.6 %
Temperature: 36.9°C
P1063 - 002 - Control Range Not Reached - Intermittent
Freeze Frame:
RPM: 2079 /min
Torque: 206.7 Nm
Speed: 117.6 km/h
Duty Cycle: 1.0 %
Voltage: 13.68 V
Pressure: 546.7 bar
Duty Cycle: 42.6 %
Temperature: 36.9°C
P1063 - 005 - Control Range Not Reached - Intermittent
Freeze Frame:
RPM: 2079 /min
Torque: 206.7 Nm
Speed: 117.6 km/h
Duty Cycle: 1.0 %
Voltage: 13.68 V
Pressure: 546.7 bar
Duty Cycle: 42.6 %
Temperature: 36.9°C
P1063 - 004 - Control Range Not Reached - Intermittent
Freeze Frame:
RPM: 2079 /min
Torque: 206.7 Nm
Speed: 117.6 km/h
Duty Cycle: 1.0 %
Voltage: 13.68 V
Pressure: 546.7 bar
Duty Cycle: 42.6 %
Temperature: 36.9°C
Readiness: 1 1 0 0 0
i have no idea what this means. lol.
Old 18th April 2013, 03:57 PM
you'll need to clear all the codes in case they are old ones and try again too just to see what still comes up currently
Old 18th April 2013, 04:42 PM
Fuel pressure regulation could well be related to filter if it's clogged.
Old 18th April 2013, 06:35 PM
Iv cleared them and changed the fuel filter although the one that was one looked to have been changed.
Iv just got two fault codes one for right engine mount short to ground and the one for the transmision mount, but i can live with them for the moment.
So all going well i should be ableto make it down to prestige on sunday.
