D2 - Transmission Gearboxes, diffs, drive shafts. |
Thread Tools
Display Modes
Sure you chaps have already done all this but on Audi Pages under Transmission you can change the behaviour of the D2 shift pattern.
www.audipages.com Mine is a D2 S8 1998 Model and it didn't accept any codes. After analyzing it the S8 transmission has 001XX instead of 000XX. So after coding the transmission module to 00111 instead of 00101 it made a massive difference. Felt a lot more sporty and a lot less 'dumb'. |
A subject after my own heart.
There is a member of AudiWorld KjellA, who swaped his 97 A8 for an FE S8 and bemoned the shift patterns on his new trans. On his 97 TCU he was able to bounce the needle off the redline without upshifting while in Tip and, once again, while in tip there was no kick down while under hard accelaration. There was a change in TCU coding about the time of the FL or maybe a bit earlier as the only codes a PF TCU would accept were 00000 or 00010. From the FL onwards coding was available dependant on the market and it is possible to recode boxes to suit driving styles. In the midddle there seem to be some TCU on PF cars (my 98 S8 for one) that have a FL code. In my case it was 00101. KjellA found that hecould recode his TCU to 00131 which gave it the charateristics of his on 97 TCU allowing full control while in tip. As yet I have not been able to achive this as my TCU seems only willing to accept 00101, 00111, 00011 and 0001. 00011 puts the box into Limp Mode so thats no good. 00111 seems to make the box more responsive and a bit quicker to shift. 00001 dosen't seem to do anything that I can tell. I have some links at home that explain all the codes etc. I'll post when I get home. I want the complete control codes on my box so that while in tip I don't kickdown and can take it to the redline and hold it there without an upshift. Work in progres.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. ![]() Last edited by Conan_the_Librarian; 24th March 2009 at 01:23 PM. Reason: Correct error (emboldened) |
Mine was 00101 and is now 00111 which as you say made a good difference. I'm happy with that for now.
The codes are on Audipages ![]() |
Here's the links I was on about above
Link 1, 2, 3, 4. The text of my e-mail correspondence > Hi, > > > > My name is Mike from the UK I am on Audiworld, Tyresmoke and the > forum.a8parts.co.uk as Figure 11. I emailed Paul Waterloo the other day > about recoding the TCO on my 98 S8 and he suggests I e-mail you. I want > to be able to drive in tip and have no kickdown Currently I redline in all > gears and change up (don't mind that) but want to get rid of kickdown so > it wont change gear when I dont want it to. > > Current code is 101. 111 works but just moves the change up 600 rpm > earlier. > > > Any ideas what code might work? > > Regards, > Mike > Hi Mike, > > > I haven't been looking for exactly that configuration, and a kind of doubt > it exists. I believe it's either the "old style" Tiptronic mode behavior > (all manual) or the "new style" (semi auto). > > I find it a bit strange that you have the "new style" behavior on your > '98, I thought it came with the facelift. My former '97 had the old style > tiptronic. > > > Anyway, I recoded from default 000101 to 000131 on my '02 S8, and that > works like a charm. It will not upshift at all, just hit rev limiter instead. > And no downshifts unless rpm gets really low. > > > > Regards, > > KjellA > A link to the VagCom Wiki on TCU recodeing
Cheers!
Tried 00131 yesterday but it didn't accept it, i'm happy with 00111 for now ![]() |
My 00 S8 had 00001 when i checked. Changed it to 00011 and it feels different in the way that it autoshifts at 7000rpm at "manual mode" and i feel that its shifting earlier(lower rpm's) from 2-3 and 3-4 when doing the daily driving in "D"
Wondering if 00111 or 00131 would do me any good? Would there be any risk in trying any of those codes?
2003 Daytona Grey RS6 2000 Silver S8 2005 A6 1.8TQ Premium 1993 Audi S4 2.2 TQ MTM 330 (my first love!) |
Just record the original codes and if it doesn't work reset to the original codes.
The only code it accepted was 00011. And what a difference....
Finally it wont downshift before apx 1300rpm rpm in D and 1200rpm in 5.gear and 1000 rpm in 4-3-2 gear when in manual mode. And the fact that it downshifts more then 1 gear in D without kickdown is sweet as can be. Gutta love this mod ![]()
![]() Quote:
