Old 5th May 2013, 11:28 PM
Default Quick look at the D3 Fridge / Coolbox
There are two versions, a Coolbox at around £1000 for 5 seater cars that required a center pop up headrest, and a Coolbox with bar compartment for 4 seater cars with individual electric rear seats @ £1450 that instead of a pop up center headrest, comes with a glasses compartment with 2 glass tumblers.
I have the former in my 4.2 Tdi.
Note this is a proper refrigerated unit, not just a chilled feed from the A/C like you might get in the glovebox or similar. Its a very well insulated, electrically powered fridge that runs whenever the ignition is switched on. It does refrigerated remarkably well
The door, located between the two rear seats:
And with the door open:
And yes, it uses some space in the boot, but unless you carry singularly large items a lot, then actually the luggage space is still very sufficient and you can pack things around it easily:
ID:	6008   Click image for larger version
ID:	6009   Click image for larger version
