Old 7th May 2013, 02:26 PM
SilverS8 SilverS8 is offline
Default Sunroof stuck Tilt mode......
Driving home in the sun with tilted up, due to the nice weather i figured i'd open it all the way.. Nope, wouldn't open.. Just tilt's downwards about 1 cm and goes back to max tilt mode..
Tried ignotion off and on but no help. No help with the comfort-locking either..
Any ideas?
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 7th May 2013, 03:58 PM
Not good... but I'm pretty sure you can pop the cover off and close it manually with an allen key
Old 7th May 2013, 04:13 PM
Amanda Amanda is offline
Isn't there a special tool hidden in the roof somewhere to close the sunroof.
Old 7th May 2013, 04:57 PM
RanjS8 RanjS8 is offline
Default Sunroof motor
Sounds like either the sunroof mechanism is really stiff and the sunroof motor has stopped working properly.....the sunroof motor covers just pop off with careful levering and then there are 3 screws to drop the motor....leave the motor connected to power and check it still turns....or if it has broken.....
But before doing that check to see if any fuses have blown....where the spindle from the sunroof motor sits ....you might be able to turn the mechanism to close the sunroof with a large flat blade perhaps....and I would try to get some wd40 on the mechanism
Old 7th May 2013, 08:36 PM
Thanks for all the replies
I did close it manually with the tool hidden in the fusebox cover, Its very smooth and opens easily in all ditections when done manually...
When ignition on it moves apx 1 cm back and forth before it stops, this happens if it is on tilt,half open, fully open...
Is there anyway to calibrate/reset the sensors like on the windows?
2000 Silver S8
Old 8th May 2013, 07:33 AM
No idea what this is, hope you get it sorted soon.
Could you post a photo of the tool and its location?
Old 8th May 2013, 08:28 AM
It could be the pinch protection playing up maybe.
Jim do you not have a owners book? The tool looks like this
And on a PF it's stowed inside the cover for the sunroof, int light lens off, 2 off phillips screws out and down comes the cover with a pull.
Old 13th May 2013, 04:05 PM
Guess it must have been a vacationing gremlin of some sort..
Works like a charm (for) now
Jan
2000 Silver S8
