Old 31st March 2009, 10:15 PM
sutherland sutherland is offline
Default Creaky Headlining
I have all sorts of annoying creaks that appear to come from my headling (02 D2) when as the car body flexes over bumps etc., but despite my best efforts I cannot track down he precise cause or location. I tried screwing down the sunroof frame a bit harder - no difference. Does anyone know a possible cause of this or can anyone provide me with the complete procedure for removing the headlining so that I can find the source and refix everything securely?
Thanks.
Old 1st April 2009, 08:08 AM
Definitely headlining? I sometimes get creaks from the door trim and a bit of silicone spray sorts that out.
Old 1st April 2009, 08:46 AM
entwisi
Guest
Posts: n/a
My steering column has a squeak from time to time that bugs me...
One problem with such a quiet well insulated car is you hear all the tiniest rattles inside but none of the external noises of impending doom. My gearbox/pump/TC noises were almost impossible to hear inside but soon as you opened the door it was bleeding obvious there was something wrong.
Old 1st April 2009, 03:21 PM
Ian@A8parts will be around soon and he has removed and refitted several headlinings. I'm sure he will be able to help.
Old 1st April 2009, 05:40 PM
Is the column squeak from the top near the wheel or further down? Sometimes the bit where the column goes through the bulkhead (rubber grommetty-thing) can get dry and needs a wee bit of lube.
Old 1st April 2009, 08:30 PM
Mind is certainly from the roof area - seems to be just above the passangers head.
Old 1st April 2009, 08:57 PM
Checked the sunroof seals?
Could still be the headlining... You don't have a roof-mount dvd screen do you?
Old 7th April 2009, 04:54 PM
No roof-mounted DVD--I've got a mortal antipathy to in-car DVD players.
I'm now certain that the noise is coming from the area between the front edge of the sunroof and the front edge of the passenger sunvisor. If I push up on that area it stops the noise. Is there anything particular in there that could be moving? Anything I should tighten up? If not, does anyone know the procedure for getting into that area?
Old 23rd February 2010, 05:34 PM
s8 alan s8 alan is offline
Thanks.
hi sutherland my first post i dont have the answer but i have the same problem on my 99 s8 but it only happens when its sub zero apart from that its fine
Old 28th February 2010, 09:49 AM
Welcome S8 Alan glad to have you along. Why don't you post a bit about yourself with some photos of your 8 in the introductions section. Be great to se you at one of the events this year..
