Old 20th June 2013, 03:17 PM
Default How often should we change fuel filter?
On my D2 I changed fuel filter 3 years ago and made 30000 miles. Time to change it again?
How often fuel filter needs to be changed?
Old 20th June 2013, 03:48 PM
I'm not sure there's a stated change interval for the petrol engines? Don't have my service book in front of me but would expect it to be listed if it is.
I know I've changed mine too, but only because I couldn't find a record of it being done before
Old 20th June 2013, 08:34 PM
I would say yes Sergey but theres no stated interval on autodata or tolerance which is the bibles used by workshops, which to me is a tad odd.
I changed mine last major service last autumn as I feel it should be done every 3 years or 30,000 miles. It seems crazy to me to have a filter in line then not recommend changing it at certain intervals!
Old 20th June 2013, 09:10 PM
Cheers Neil. Just ordered.
Here is the kit you need if you want to do it yourself for the following engines:
V8: AQG,AQF,ARU,AQH,AKC,AVP,AUW,AVN,BCS,AYS
V6: APR,AQD,AMX
W12: AZC
Fuel filter: 441 201 511 C
Two filter crush washers: N 013 81 28
Two more filter crush washers: N 013 81 49
Torque 23 Nm.
Optional hardware (in case you never changed it may be rusty and worth renewal):
Bolt: N 906 264 01
One more bolt: N 021 07 47
Screw: N 904 968 02
You will need to remove plastic cover to get access. Another 6 rusty bolts (optional):
6 bolts: N 090 11 62
Old 30th June 2013, 09:03 PM
Changed fuel filter today. Not difficult at all.
Had to drive to Halfords to purchase 22mm spanner.
Interestingly, in all DIY kits I've seen the largest spanner is 19mm
