VCDS (aka Vagcom) For all your electronic debug / diag advice queries and mods. |
Hi guys ,
I've had a go with my new genuine VCDS tonight , On selecting auto scan and after selecting for the D2 it comes up with modules to scan Scan 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77 02 Then it cycles through to 56 and throws up a fault code 56 radio 1 fault found 01044 control module incorrectly coded 35-00- - Any ideas what that is or how to fix it ??? Then after that it goes to module 57 and then stops and I get an error saying Interface status = 0 Interface not ready Possible reasons Incorrect com port selected Interface not plugged in Ignition not turned on K-line stuck Firmware update needed For more details use test on options screen Any ideas why , module 57 is for the TV and my car doesn't have one , is this the reason why it's not continuing or is there a problem elsewhere Cheers Dave |
sounds like the CAN module is coded for TV. check the coding on module 07
![]() Quote:
How do I know if it is or not , I didn't think mine supported CAN , or am I getting confused here with something else ![]() |
PF, so no CAN
![]() Go into coding in VCDS and it should have helper hints for it.
![]() Quote:
I'll have a butchers when's get home tonight ![]() |
